65 starfire
65 starfire
just out of curiousity , can ayone tell me what series the 65 starfire falls under, i want to make sure so i get the right torque specs, thanks very much to all, this site is such a great help, will.
torque specs
thank you for the info on the series, basicley i need the torque specs for the front a frams , my manual is in very hard shape , would appreciate it , thanks again ,will.
upper control arm pivot shaft nuts: 55 ft/lb with car on the ground
pivot shaft-to-frame nuts: 105 ft/lb
ball joint stud nut: upper - 40 ft/lb (minimum), lower - 70 ft/lb (min)
lower control arm pivot bolts: 75 ft/lb with car on the ground
Kyle's 77 Cutlass
January 1st, 2014 09:06 AM
Oldssupreme
February 3rd, 2013 06:26 AM
Oldssupreme
February 3rd, 2013 06:24 AM
