Posi Units & Gearsets for 12-bolt Chevy
Old May 9th, 2012, 01:00 PM
507OLDS's Avatar
I have a few set of gearsets & rebuilt Eaton posi units,for 12-bolt Chevy.The posi units are rebuilt with the good clutches,not the junk that comes in the new ones.
GM 3:31,dated 1966,with 3-series Eaton posi,$450.00
GM 3:55,dated 1970,with 3-series Eaton posi,$450.00
Richmond 3:73's,new,for 4-series carrier,with 4-series Eaton posi,$500.00
507OLDS is offline
Old May 16th, 2012, 07:54 PM
Olds462's Avatar
Do you have any posi units for a 1970 'O' type 12 bolt?
Olds462 is offline
Old May 17th, 2012, 04:30 AM
507OLDS's Avatar
I have the #588 posi unit,for the GM 3:42-up gears,for 28-spline axles,and I also have the #672 posi carrier,for the same GM 3:42-up gears,for 31-spline axles.
The #588 is $450.00
The #672 is $500.00
Both are rebuilt,and have new bearings installed.
You can run the new Richmond 3:42/3:90 gears with these carriers,if you mill .100" off the backside of the ring gear.I've done it many times with no issues.
507OLDS is offline
Old May 17th, 2012, 02:58 PM
Olds462's Avatar
How would I go about finding out what spline shafts are in mine?
Olds462 is offline
Old May 18th, 2012, 05:50 AM
507OLDS's Avatar
The 31-spline rears were only offered in late-67 & 68.All of the other O-axle rears have 28-spline axles.If your rear is not original to the car,and are unsure of the year,you can remove one of the shafts & count the splines.There are 4 nuts holding it in,located behind the brakes.You do NOT need to remove the rear cover to remove the axle.
507OLDS is offline
Old May 18th, 2012, 02:39 PM
Olds462's Avatar
I will check to be sure and get ahold of you. Thanks for the help.
Olds462 is offline
Old May 21st, 2012, 05:58 PM
Olds462's Avatar
Hi Brian, Sorry it took so long to get back to you. Work is crazy lately. I counted the splines on the shaft and it's a 28 spline shaft. Do you still have a posi available for this. Looking to go with a 3.42 gears for this. If you could please send me a PM.
Olds462 is offline
Old May 21st, 2012, 07:29 PM
507OLDS's Avatar
Yes,I still have the posi unit.
507OLDS is offline
tim72
Drivetrain/Differentials
24
August 7th, 2014 06:00 PM
monzaz
September 13th, 2013 10:33 PM
monzaz
May 11th, 2013 09:11 AM
monzaz
May 30th, 2012 04:08 PM
J-(Chicago)
September 30th, 2009 09:32 PM
Quick Reply: Posi Units & Gearsets for 12-bolt Chevy
