1965 olds 330 High compression and powerglide trans
Old December 5th, 2008, 06:55 PM
tlucas07
Guest
Posts: n/a
This is a 1965 olds 330 and powerglide trans. I just took it out of my f85 it runs great and the trans shifts fine. it has an edelbrock carburetor and intake it also has hei distributor and has 60K on it. I also have all the original parts that came off it carb, intake, distributor, alt. It dose not use any oil. This is the info on the engine 1965 330 high compression 10.25.1 315 Hp Code is T536312G. The trans is a powerglide the code is 65 mk 059. I will not ship this !! You must pick this up! The price is $950.00 obo
Thanks Todd
Old December 8th, 2008, 10:47 PM
Just the facts...
BILL DEMMER's Avatar
if that trans is an olds trans. it is not a powerglide, it is a jetaway, also known as a thm300, buick super turbine 300, or pontiac tempestorque . it should also have a green switch-pitch/variable vane torque converter and two electrical connector terminals on the driver's side. the powerglide is a completely different trans. and shares no parts with the b-o-p 2-speeds.
bill
BILL DEMMER is offline
Old March 23rd, 2009, 11:40 AM
63 F85 Cutlass's Avatar
If you want pickup, please post a location, I'm posibly interested, but will need a location. Thanks
-Ryan
63 F85 Cutlass is offline
MudEye
June 2nd, 2015 10:45 AM
kanner1
October 8th, 2011 05:31 PM
Ficks
March 25th, 2011 06:43 PM
bobsrats
April 2nd, 2009 07:36 AM
cts-v
January 10th, 2009 04:55 PM
Quick Reply: 1965 olds 330 High compression and powerglide trans
