1971 -1975 shift lever for column shift tilt column
Old October 23rd, 2012, 05:18 PM
Rocketbrian's Avatar
I am looking for a mint shift lever for a column shift tilt steering column. The part number is 408659. I believe the same lever is used in all Olds Cutlasses and Deltas from 1971 to 1975. It appears to be slightly longer than the non-tilt shift lever and has two minor bends in it. I have attached a picture. Thanks.
Rocketbrian is offline
Old October 24th, 2012, 06:21 AM
oldspackrat's Avatar
Well I learned something last night when I saw this post. I thought the non tilt & tilt shift levers were all the same. I checked some of my inventory & found that you are correct. I have a column shift tilt that came from a car that caught on fire & I compared a regular shift lever to the one on it & was surprised to see they are different. That one has the end melted off of it so I'm sure you don't want that one. I dug through my box of column levers & did find one from a tilt. It has some tiny pimples on the large part near the end so I doubt if you'd want this one either, but here are some pictures for anyone else that may have some of these.
The pictures show a regular shift lever next to the burnt up one, then next to the other one.
http://i856.photobucket.com/albums/a...-26-11_902.jpg
http://i856.photobucket.com/albums/a...-27-11_170.jpg
http://i856.photobucket.com/albums/a...-29-53_878.jpg
http://i856.photobucket.com/albums/a...-31-01_108.jpg
oldspackrat is offline
Old October 24th, 2012, 08:14 AM
Thanks for looking for the part and the picture comparisons. The tilt lever is longer than I thought, quite a difference in the two.
Hopefully something will turn up. At least Olds kept the same lever for a few more years and used it for the big cars as well.
PS - I always find it great to learn some new info on these old Oldses even though I've been at it for many years.
Brian
Old December 4th, 2012, 05:33 PM
bumping thread, no luck yet.
Old October 2nd, 2013, 10:18 AM
customcruiserfan's Avatar
So, by this post I can't swap my pitted 1971 Custom Cruiser gear selector for a nicer one from a 1977 Toronado (both with tilt column)? The toro does seem to be smaller, but I thought it'd still work in my column.
Thanks for any reply.
CCFan
customcruiserfan is offline
hvysupreme
February 18th, 2017 12:40 PM
glparker389
March 19th, 2014 04:46 PM
Bitburger
December 30th, 2012 04:49 PM
67442nut
December 19th, 2010 10:21 AM
ros6872
February 24th, 2010 05:50 PM
Quick Reply: 1971 -1975 shift lever for column shift tilt column
