66 400 engine flexplate
I have a friend who is having starter problems and the shop has told him he needs a flexplate , confirmed damaged teeth on flexplate as a result of PO installed a 700r 4 and the adapter that was used is too thick, so now needs a flexplate, does anyone know about a special flexplate needed for this engine confirmed 390925 E block. any help would be apreciated
Yes, the early ('64-'67) engines all had a different bolt pattern on the crank hub and thus need a different flexplate. E-mail me direct if you'd like one: drolds1@bellsouth.net. Thanks, Bob.
