'68 350 4bb fuel pump to carb line
Need an original pump to carb fuel line for a '68 350 4 barrel. All repos I have tried have been at least 1/8 to 1/4 inch short & every thing is stock. Wasted $75 now trying 3 diff. vendors lines, WTF?
Any help appreciated.
Leigh
952-997-3515
Leigh
952-997-3515
That sounds a little weird to me. I've used InLine Tube twice and have yet to have a problem. Here is a different take---try a line for a '79 Pont. T/A---used an Olds 403 small block.
What vendor's products did you try?
Maybe you have a different fuel pump or thicker carb gasket causing the issue.
Try locating a suitable replacement at a junk yard that hasn't been tampered with.
Also, if you say you are within 1/8 of an inch, try just starting the threads on each end BEFORE you tighten on or the other completely---might need a little tweaking.
1k442
October 3rd, 2012 08:38 AM
oldspackrat
October 10th, 2011 07:09 PM
stlbluesbrother
March 21st, 2011 03:24 PM
