72 442 Brake Cast Combination Valve
Old January 19th, 2014, 09:18 AM
KZ442's Avatar
I have a 72 442 with power disc brakes and I am looking for the cast NOT BRASS brake combination valve that mounts on the frame. I sent mine to Karps to be rebuilt and they said the bore was to pitted to rebuild. Please let me know if anyone has a NOS one or a clean used one.
Thanks,
Karl
KZ442 is offline
Old January 19th, 2014, 06:22 PM
69442murph's Avatar
Is this the one you are looking for?
thanks
69442murph is offline
Old January 20th, 2014, 07:47 AM
KZ442's Avatar
thanks
Yes
Is this off a power disc brake car and if so what year.
KZ442 is offline
Old January 20th, 2014, 08:32 AM
69442murph's Avatar
I remember taking off a 71 or 72 Cutlass a very long time ago and been sitting since...don't recall if disc or drum...sorry...
thanks
Old January 20th, 2014, 12:40 PM
The Rocket Astronomer
lunaboy's Avatar
I have two or three of those ( if anyone else needs one ) as I am using the 70 style.
lunaboy is offline
Old January 21st, 2014, 12:27 PM
lunaboy's Avatar
0411
I have a bendix 0411, does not look like the one
on my 70 442. what do these cost to rebuild anyway.
lunaboy is offline
Old January 21st, 2014, 01:14 PM
507OLDS's Avatar
I have seen Bendix and Delco,for the 71-72. Not sure if there was a reason for the different brands. They also have a Julian date,but it can't be seen when installed.
507OLDS is offline
Old January 21st, 2014, 02:11 PM
That looks exactly like the one I have on my 72 with PDB. I cleaned mine up when I did the rebuild last year. Here's guaranteed 1972 PDL for comparison.
Freshly removed and rear port blocked
Other side
Cleaned, sprayed with clear (looks like painted silver, but the flash just shows it brighter) and partly reinstalled
Allan R is offline
Old January 21st, 2014, 04:56 PM
507OLDS's Avatar
Allan has the Delco version,but you can see that they are the same.
If you remove the frame bracket,you will see the Julian date cast into the body of the valve.
507OLDS is offline
baloo
December 14th, 2014 07:58 AM
1970VistaCruiser
June 2nd, 2014 07:09 PM
brown7373
March 27th, 2014 01:34 PM
1970442lover
Paint
23
November 10th, 2013 09:59 AM
milehigh
August 31st, 2012 03:33 AM
Quick Reply: 72 442 Brake Cast Combination Valve
