Brass Adapter T Fitting
Old April 20th, 2010, 01:12 PM
olds67's Avatar
hello guys
I have to connect the pressure gauge switch electrically but can not find links that send in this part of Italy, some of you can help.
thanks
Delmont 88 425
olds67 is offline
Old April 21st, 2010, 05:10 AM
ROCKETMAN269V's Avatar
Smile fitting to Italy
Is that for an oil pressure gauge/lite? If so, it would be 1/8" NPT thread; I have the fitting. E-mail me for details. Thanks, Bob.
ROCKETMAN269V is offline
Old April 21st, 2010, 11:32 AM
olds67's Avatar
ok thanks
olds67 is offline
Old April 21st, 2010, 04:55 PM
greenslade's Avatar
shoud be able to find that fitting in any plumbing supply store,or any place that services big trucks should have them.
greenslade is offline
Old April 21st, 2010, 06:50 PM
1972 Cutlass 455
silverriff's Avatar
They sell everything you need to install the oil pressure gauges in an autometer gauges install kit. They sell the whole kit at most big autopart chainstores for pretty cheap, like $8.00 including the t-fitting, hose, and all different nipples/caps for assorted applications.
silverriff is offline
Old April 21st, 2010, 06:53 PM
2blu442's Avatar
Guys, he's located in Italy so he may be needing someone here to ship one to him. I enjoy hearing about Oldsmobiles scattered around the world but imagine working on them overseas is difficult!
2blu442 is online now
Old April 21st, 2010, 06:56 PM
1972 Cutlass 455
silverriff's Avatar
You mean they don't have an Advance or Autozone on every corner like here in Baltimore???
Old April 22nd, 2010, 02:06 AM
Registered
Bluevista's Avatar
If you go to the parts store in Italy looking for Olds parts and they can't find anything make sure the counter guy types "Oldsmobile" into the computer and not "Oldsomobile".
The stores there would have metric fittings but if the gauges are metric they may have an adapter.
The NPT male to metric female adapter is a tough one to find here.
A hardware store or plumbing supply there may have something but that fitting but is a specialty type, most any place here would have a female tee and short nipple.
You want to keep the oil pressure light working and have the gauge also I take it?
Summit Racing and places like that ship internationally?
http://www.summitracing.com/parts/NOS-16775NOS/
http://www.summitracing.com/search/D...brass++fitting
Bluevista is offline
Old April 22nd, 2010, 02:35 AM
Yellowstatue's Avatar
Oldsolobilo
Yellowstatue is offline
Old April 22nd, 2010, 03:34 AM
olds67's Avatar
yes!!
The problem is that I'm in Italy and parts is not easy to have them here do not match the threads of this hydraulic fitting.
olds67 is offline
Old April 22nd, 2010, 03:36 AM
olds67's Avatar
we are the shop but still have to order in the USA and ask me insane.
I better buy it myself, but no store where I found the USA sends in Italy
olds67 is offline
Old April 22nd, 2010, 03:58 AM
olds67's Avatar
Summit sends in Italy, but I could not find the connection, perhaps the name was wrong, that it takes to mount an extension cord, because the thread is short.
you can find the extension cord?
thanks also I can buy from Summit
olds67 is offline
Old April 24th, 2010, 03:01 PM
olds67's Avatar
this is a problem,the adapter is short and i can not screw it...
exists an extension?
olds67 is offline
Old April 24th, 2010, 03:55 PM
2blu442's Avatar
I've seen people use a small piece of steel pipe to raise the "T" or even the sending unit up above the waterpump. Is the male threads on your T part of the brass piece, or are they threaded into it? Could you replace them with a short pipe nipple that's threaded on each end? John
Old April 25th, 2010, 02:41 AM
olds67's Avatar
yes John
the male braid to the big block and the T is all in brass, could be used the braid of the pressur swicth, to cut it and to braise it to the T but I am afraid that does not hold.
this you say that it can go, it is higher
olds67 is offline
Old April 25th, 2010, 10:08 AM
citcapp's Avatar
Olds67, You picture will work that is the same as what I used on my 455.
citcapp is offline
Old April 25th, 2010, 10:23 AM
olds67's Avatar
ok citcapp
expect to post a photo...
olds67 is offline
Old April 25th, 2010, 10:28 AM
citcapp's Avatar
Will do, i did not use a sensor though Instead I used a under hood gauge in its place and did not hook the light back up
citcapp is offline
Old April 25th, 2010, 10:30 AM
olds67's Avatar
I'd like to have everything under control inside the car, this is why
olds67 is offline
Old April 25th, 2010, 11:09 AM
citcapp's Avatar
Here is the picture
citcapp is offline
Old April 25th, 2010, 12:31 PM
2blu442's Avatar
olds67, yes the last picture you posted, mounted like citcapp did on his car would resolve your clearance problems. John
Old April 25th, 2010, 02:04 PM
olds67's Avatar
yes is a good image to go ahead, theres an extension on that of citcapp that should be what sells the summit.
guys thank you so much
olds67 is offline
Old March 4th, 2011, 10:31 AM
Tony72Cutlass'S''s Avatar
Hey Pat,
That's an awesome set up, i think i'm going to do the same thing on my 72 Cutlass 's' project, as having an under the hood gauge for reference would be great,
cheers,
Tony
Tony72Cutlass'S' is offline
Old March 5th, 2011, 03:25 AM
And the '80 - '84 Olds Regency's (probably the Delta's too) with the guage package have the very same elevated extention brass fitting (elbow) as used on the '68 Olds with rally packs... PN 401559
Old March 6th, 2011, 12:58 AM
olds67's Avatar
is very comfortable, my problem is that the Chinese have bought the gauge is not worth anything.
I think ahead to buy gauge U.S.A. or made in Italy that are the best.
olds67 is offline
montvaleplace
October 2nd, 2012 06:55 PM
jkoester122
September 8th, 2011 07:48 PM
defiant1
June 7th, 2011 10:07 AM
cfair
May 31st, 2009 09:18 AM
65 starfire
February 2nd, 2008 07:03 PM
Quick Reply: Brass Adapter T Fitting
