Engine anyone????
Old September 25th, 2012, 03:58 PM
My1st olds69"S"'s Avatar
Engine anyone????
Hello, I am looking for an engine for my 69 S, or any other parts that are in good shape. I am doing a complete restoration on the car. Looking for a 350..
My1st olds69"S" is offline
Old September 25th, 2012, 04:01 PM
ah64pilot's Avatar
This needs to be moved to parts wanted...
Are you looking for a particular year 350 or just any will do?
ah64pilot is offline
Old September 25th, 2012, 04:12 PM
Yeah I realized that as soon as i posted it..still green to this. I would love to have one closer to that year earlier or later, but almost any would do. Right now I just want to get it back on the road.
Old September 25th, 2012, 04:14 PM
Engine anyone????
Old September 25th, 2012, 04:15 PM
L69
L69's Avatar
Im in CT and I have several 350's I dont believe I have any 69's but several 68's
L69 is offline
Old September 25th, 2012, 04:47 PM
oldspackrat's Avatar
I have a shell of a '69 Supreme with the original engine still in it. It is missing the intake/carb, but otherwise complete I think.
It was running when it crashed & then went to a junk yard. I would sell it as an engine needing rebuilt as I don't know how long it sat in the yard.
I'm in Indianapolis & might be able to meet you half way if interested?
Thanks.
Scott
c. 317-727-7041
oldspackrat is offline
Old September 25th, 2012, 08:42 PM
Eightupman's Avatar
Well, the block is the same from 1969 all the way up to 1975 (or maybe 6) I can never remember. #6 heads are the year correct heads for that car, but 5-8 heads can be worked for power.
I'm in SC and have several 350 cores that require various degrees of work, but it sounds like you want a runner?
John
Eightupman is offline
Old September 25th, 2012, 08:53 PM
Fakser's Avatar
Do you have a budget? Are you looking for a turn key engine to drop in and hook up, performance parts, what type of gauges will you use, a lot of questions come up to help you find something that will best fit your need. I'm sure someone here has something for you for the right price.
Good luck
Fakser is offline
Old September 25th, 2012, 10:08 PM
Mr Shifty Sidney's Avatar
I have a 350 out of a 72 that I would like to sell. It ran when pulled, but I would really only consider it a good engine to rebuild. The car was driven 45 miles to my house and the engine was pulled. I am in southern KY just off I-65. If you are interested PM me. $250
Don W
Mr Shifty Sidney is offline
Old September 25th, 2012, 10:22 PM
RunTuWin's Avatar
I have a 350 Rocket out of a 69' that I just pulled. It still ran when I pulled it but had a rear main seal leak. I'm in California and the engine is near Fresno if interested. Looking to get rid of it for $750
Everything is there.
Here is a picture.
It also has a high performance Edelbrock Carb and Intake. I have the original intake and carb as well that I would ship.
RunTuWin is offline
Old September 26th, 2012, 05:10 AM
507OLDS's Avatar
Complete 1972 350 with TH350 transmission still attached.It was running & driving when pulled last year.Carb was removed,but everything else is still on there.
507OLDS is offline
Old September 26th, 2012, 05:32 AM
Chesrown 67 OAI's Avatar
68-70 350 use the same casting number block - so any of those would work as a "correct" motor for the car -- Must have #5 heads for your 69. I have a unassembled short block assembly that has been recently rebuilt with less than 1000 miles on it. Fresh bored .030 with new sealed Power small dish pistons, and a new Comp Cams with a near W-31 grind. Crank is NOT drilled for stick. It has an Edelbrock manifold with spread bore Holley. Dont have a stock 69 intake to sell. Email or PM me if youre interested. Was planning on taking this motor to Carlisle swap meet next week but will keep it here if your are interested. "make you good deal"!!
Chesrown 67 OAI is offline
Old September 26th, 2012, 05:56 AM
Pacecar's Avatar
I have a 1969 350 - Engine is complete intake to oil pan. 4 barrel intake, A/C engine with the alternator bracket and three row water pump pulley. Was told engine ran when I got it. Has #5 heads correct heads I believe. Located Rochester NY
Pacecar is offline
Old October 12th, 2012, 04:26 PM
Fummins's Avatar
Im in nor cal, may have some items you need.
Fummins is offline
Old October 14th, 2012, 07:37 PM
hotrodpc's Avatar
Nice to see all the offers and that the parts are available. Is OP going to respond? Anyone know if he still needs this or did he buy one?
hotrodpc is offline
805cut
May 3rd, 2012 08:11 PM
oldsman330
May 17th, 2011 04:13 PM
vettemad
March 17th, 2010 07:10 PM
import extermination
August 1st, 2009 10:09 PM
geckonz08
August 21st, 2008 07:58 PM
Quick Reply: Engine anyone????
