Looking for 1972 t3 low beam bullbs
Old July 31st, 2021, 06:35 PM
72455's Avatar
Need one (preferably 2) 1972 t3 low beam bulbs. These have the "t3" markings at the bottom, not the triangle in the center.
72455 is online now
Old August 1st, 2021, 08:40 AM
pappy's Avatar
There is a pair of low beams on evil bay now. No affiliation on my part.
pappy is offline
Old August 1st, 2021, 09:30 AM
72455's Avatar
Yup..saw those for 97 bones but not been tested..not gonna lay down that kinda green on something that may or may not work.
72455 is online now
Old August 1st, 2021, 11:43 AM
PatL's Avatar
love that cop out that is becoming more common on Ebay: "Not been tested" especially on easy to test stuff, Gets them off the hook, but I pass every single time...…….
PatL is offline
Old August 1st, 2021, 12:14 PM
Oldsdruid
rocketraider's Avatar
Unless you're going for a 1000-point restoration or never plan to drive the car after dark, why would you even want them?
At least 73-later Guide PowerBeams gave you better light.
rocketraider is online now
Old August 1st, 2021, 03:53 PM
72455's Avatar
Because I've tried aftermarket and they don't fit right...
72455 is online now
Old August 1st, 2021, 04:09 PM
Really? I’ve used aftermarket in both my 70 Supreme and 71 convertible since the 80s with no fitment issues.
Fun71 is offline
Old August 1st, 2021, 05:28 PM
72455's Avatar
Yesssir...even an OEM from 70-71 doesn't fit quite as snug as a 72....dunno why but maybe that's why the 72s are few and far between.
72455 is online now
Old August 1st, 2021, 06:39 PM
Oldsdruid
I had a 72 Supreme from 1988-94 and Wagner, GE, and Sylvania all fit without issues. Has your car ever taken a front end hit?
Old August 1st, 2021, 07:29 PM
The headlight buckets and retainers on a 72 are no different than the other years, so if there is something preventing the headlights from fitting properly on your car, the issue is most likely with your car and not the aftermarket headlights. Can’t really say too much without seeing what the issue is, though.
Fun71 is offline
Old August 1st, 2021, 07:44 PM
Old School Olds
tru-blue 442's Avatar
72, I'll dig through my stash and see if I have one. Remind me, 2 or 3 prong? I forget.
tru-blue 442 is offline
Old August 1st, 2021, 08:28 PM
Oldsdruid
2 prong hi beam (inner lamp), 3 prong low/combination beam (outer lamp).
Old August 2nd, 2021, 06:21 AM
Old School Olds
Figures. The only T-3 that I have like he wants is a high beam 2 prong.
Old August 2nd, 2021, 07:45 AM
72455's Avatar
So after some digging into my memory banks, I remembered why I went with the '72 only bulb. I was originally going to switch to halogens, but the screws for the driver side ring were seized, so I stayed with original low beams. When the passenger side light blew, I wanted to have a match for the driver side, so I had to stick with OEM. Now the driver side is blown, so I'm gonna have to figure how to get the screws out. Once I do that, I'm going with halogen both sides and new screws.
Sorry for any confusion.
72455 is online now
Old August 2nd, 2021, 08:11 AM
Old School Olds
Amazon Amazon
Old August 2nd, 2021, 11:11 AM
Oldsdruid
PB Blaster or Kroil and let them sit a few days.
If you have an impact driver it will help loosen a seized headlight ring screw. Alternately if you have a battery operated drill/driver, set it to reverse on low torque and let it hammer the screw loose. Hold it in the screw head tight so it won't strip the Phillips head. If that happens change to a drill bit and drill the screw out.
Old August 2nd, 2021, 12:07 PM
72455's Avatar
I like the battery operated drill idea...I'll see how that works and let you know.
72455 is online now
brandon reynolds
November 29th, 2017 02:47 PM
KZ442
April 29th, 2017 05:06 PM
joesw31
December 15th, 2013 12:06 PM
Holiday 98
May 15th, 2013 09:30 PM
2X72
March 23rd, 2011 02:28 AM
Quick Reply: Looking for 1972 t3 low beam bullbs
