Wanted, 1968-72 convertible frame, chassis, not top frame.
Old December 21st, 2012, 09:08 AM
oldspackrat's Avatar
I've got a friend here in Indianapolis that is almost done with the restoration of his 1968 Cutlass convertible only to discover that his frame has been damaged in the front & rear. So he is wanting another complete frame, minus suspension parts. I told him I'd put up a post & see what happens.
Thanks.
Scott
c. 317-727-7041
oldspackrat is offline
Old December 21st, 2012, 10:21 AM
69442C's Avatar
Since he already has a conv frame, I would look for a HT frame and cut out the box pieces from the conv frame and add them to the HT frame. To do so he will need to remove from the HT frame the small braces in the center of the side rails. He'll end up with a conv frame, almost identical to an original, for a fraction of the cost. If his boxing pieces are not good, then look for a 69-72 Pontiac GP as they have boxed frames and the boxing pieces are the same as the A Body cars.
Brian
69442C is offline
Old December 21st, 2012, 10:25 AM
Brian,
Good point, I should have thought of that. With that being said, I guess we're looking for a convertible or hardtop frame now.
Thanks.
Scott
Old December 21st, 2012, 10:40 AM
69442C's Avatar
Scott,
I rembered seeing this several weeks ago and I thought his price was more than fair. He's in Erie IIRC so the distance may not be too bad if it's still available.
Brian
https://classicoldsmobile.com/forums...442-frame.html
69442C is offline
Old December 21st, 2012, 07:33 PM
Registered Luser
ent72olds's Avatar
Scott, check with WTony....he may have what you need!
ent72olds is offline
Old December 21st, 2012, 08:27 PM
507OLDS's Avatar
Scott,if you convert a hardtop frame,you should have one under one of your parts cars.
507OLDS is offline
oldspackrat
July 20th, 2022 07:34 AM
oldsmobilty
September 27th, 2012 04:26 PM
cfair
June 30th, 2012 10:07 AM
Olds luvr
December 2nd, 2010 08:26 AM
real442
Cars Wanted
January 23rd, 2008 04:02 PM
Quick Reply: Wanted, 1968-72 convertible frame, chassis, not top frame.
