2 piece timing cover
Old July 30th, 2017, 05:24 AM
Tiha's Avatar
Hi guys, anyone built they own 2 piece timing cover from a existing.
Know that stolpa sells these covers, ask my self why not cut my used in half and go on.... ?
input please!
Tiha is offline
Old July 30th, 2017, 07:41 AM
wr1970's Avatar
I have one that is cut from a original cover. Never used it.
wr1970 is offline
Old July 30th, 2017, 12:42 PM
bccan's Avatar
I made one off stock cover. Bent a little piece of sheet metal into roughly a soft "z" channel & tacked it onto upper half. Acts as sort of a canopy over the joint + forms a trough/dam to help retain bead of RTV. Doesn't leak & have no plans to use it, just a MAW that has been transferred from engine to engine.
bccan is offline
Old July 30th, 2017, 04:01 PM
RROLDSX's Avatar
I tig welded an 1/8" strip on the lower half, split the bolt holes in half. Using grey silicone it has no leaks.
RROLDSX is offline
Old July 31st, 2017, 04:45 AM
Tiha's Avatar
Really cool guys, is it important to split the cover directly at the bolt holes.
maybe someone can insert some pics ??
Tiha is offline
Old July 31st, 2017, 06:35 AM
Run to Rund's Avatar
I have made them by cutting across the upper 3/8" bolt holes, seal with RTV. Has worked for 44 years. No flap, no complicated stuff.
Run to Rund is offline
Old August 3rd, 2017, 04:44 AM
Tiha's Avatar
Originally Posted by run to rund
i have made them by cutting across the upper 3/8" bolt holes, seal with rtv. Has worked for 44 years. No flap, no complicated stuff.
thanks...my way!
Tiha is offline
Old October 29th, 2017, 08:03 PM
honkeycat's Avatar
Unless your changing cams all the time, not needed
honkeycat is offline
Old October 31st, 2017, 04:30 PM
MOTORHEAD
11971four4two's Avatar
[QUOTE=honkeycat;1052749]Unless your changing cams all the time, not needed[/QUO
LoL
maybe you would like to change your cam degree / timing
if you do your 2 piece right
you can keep water pump bolted to the up segment
11971four4two is online now
Old October 31st, 2017, 04:39 PM
MOTORHEAD
the wagon was all stickered up
TRI CITY Competition
from michigan
were you there???
please tell me more
THANKS
b
Old November 9th, 2017, 05:16 PM
honkeycat's Avatar
[QUOTE=11971four4two;1053202]
LoL
lol I have a 2 piece timing cover
Almond900
November 1st, 2016 09:29 PM
jpc647
June 10th, 2013 11:48 AM
Mr Nick
November 10th, 2012 09:33 PM
Indy_68_S
Brakes/Hydraulic Systems
January 2nd, 2011 09:23 AM
442scotty
May 13th, 2009 05:42 PM
Quick Reply: 2 piece timing cover
