350 heads and carb
Old May 24th, 2016, 06:53 PM
Otto Karl's Avatar
Question 350 heads and carb
I'm looking at a 1970 convertible for my first classic Cutlass. It is very clean but I wanted the 350 4bbl. It has the matching 2bbl, lower compression ratio motor. I was thinking about maybe later making it like the 310 HP engine. Would this just be a matter of adding the 10:25 to 1 heads, 4bbl and manifold?
If this would do the trick can anyone roughly guess the cost for parts alone? I'm guessing it's not worth starting with the lesser engine but am curious either way.
Otto Karl is offline
Old May 24th, 2016, 07:03 PM
Welcome to the site. The compression ratio is raised with hi comp pistons.
oldcutlass is online now
Old May 24th, 2016, 07:10 PM
Otto Karl's Avatar
Thanks.
Thanks for the welcome. I'm no mechanic and I appreciate the info. I guess I should clearly not start there if I wouldn't want it as it is.
Old May 24th, 2016, 09:10 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Add a Performer RPM intake, Qjet or Street Demon 4bbl and a mild cam. It will out perform the 1970 high compression 350 due to the original peanut cam. All on regular gas.
olds 307 and 403 is offline
Old May 25th, 2016, 08:01 AM
Otto Karl's Avatar
Thanks Olds.
lunaboy
September 24th, 2018 10:15 AM
crazy'boutOlds
September 12th, 2010 05:46 PM
gearheads78
November 10th, 2009 09:31 PM
dharlett
September 23rd, 2009 03:30 PM
shaks 442 clone
October 18th, 2008 09:41 AM
Quick Reply: 350 heads and carb
