Aftermarket torque converter...
Old April 10th, 2012, 02:47 AM
Stevec's Avatar
Was toying with the idea of replacing the torque conv while the engine is out.
Was thinking of something like 2200-2400.
Any suggestions? tips? Recommendations?
Do I need a tranny cooler? Etc. Or should I Just keep running the stock one?
Thanks for any help..
Stevec is offline
Old April 10th, 2012, 03:00 AM
Stevec's Avatar
It's a 400 engine with a th400 and 3:55 gears. Cutlassefi hooked me up with a roller cam
Rh282/350 rh294/340 110+4 is the grind of the cam
Stevec is offline
Old April 10th, 2012, 07:01 AM
It sounds fine to me, I would see what cutlassefi recommends also. If it's just a weekend cruiser, you should be fine without one.
oldcutlass is online now
Old April 10th, 2012, 07:15 AM
455man's Avatar
I'd think a slight stall would help but check with cutlassefi. He knows your motor.
455man is offline
Old April 10th, 2012, 07:42 AM
car guy
gearheads78's Avatar
In a high performance application the torque converter is one on the most important selections you can make. It will truley make or break a combination. You should always run an extra cooler on the street with a stall converter. Its cheap insurance to help keep the temps down.
I know a lot of people are not going to agree with me but the generic converters most people use are inefficient junk. I learned myself the difference with a car. $179.00 cheapie converter and switched to a good ATI converter that cost me just under $450.00 (9 years ago) The car picked up 4 tenths at the track and was much more street friendly around town. Both were 2500-2800 11" converters.
The best thing to do is call one of the good converter companies and give them all the info about your car (you will need the duration @.050 numbers for that cam) and let them tell you what you need. I have had great luck with ATI but there are many others that make good converters.
gearheads78 is offline
Old April 10th, 2012, 08:32 AM
Stevec's Avatar
Thanks guys..
I apreciate the feedback..
Stevec is offline
Old April 10th, 2012, 10:14 AM
380 Racer's Avatar
X2 except I like Coan.
380 Racer is offline
Old April 10th, 2012, 10:21 AM
Chevy budget Olds powered
coppercutlass's Avatar
I got a cheap one and it was a 10 in. advertised 2600-2800 and its closer to 3000 rpm it works good but if money allows I'm putting in a nice one or having mine redone locally. I ran a jegs 2300-2500 and it was the same as my tci 2000-2200 stall. The tci I used was the saturday night special it was good and the price didn't break the bank.
coppercutlass is online now
Old April 10th, 2012, 10:34 AM
car guy
I have also heard good things about Coan. I ran a Neal Chance in my race car but that was a $1200.00 converter last time I was in touch with the new owner he had it down in the 5.30's
Old April 14th, 2012, 02:51 PM
panos's Avatar
I have a 11" custom made from http://www.abruzziracing.com/main.html
Works like a charm
panos is offline
Old April 14th, 2012, 05:17 PM
ziff396's Avatar
I am running a Hughes 2500 on mine. Seems really nice for the street with the 455 moderate build, 3.42's. No slushy shifts at part throttle, and great response when hitting it.
ziff396 is offline
Old April 14th, 2012, 06:59 PM
TripDeuces's Avatar
I had a cheap one balloon and wipe out my crank. Stick to the good stuff.
TripDeuces is offline
Old April 18th, 2012, 07:28 PM
SBORule's Avatar
X2
Especially with a BBO that makes a ton of torque. Get one with anti-balloon plates.
PTC makes good convertors too. Checkout their website, you might find their prices aren't too bad either.
SBORule is offline
Old April 19th, 2012, 09:17 PM
ah64pilot's Avatar
Do you guys know of anyone that makes a switch pitch these days? I was thinking PATC made one but I couldn't find one on their site for a TH400.
ah64pilot is offline
Old April 20th, 2012, 05:46 AM
TripDeuces's Avatar
I had Jim Burek at PAE rebuild my S/P converter a few years ago but heard he is no longer in business. Here's his number at the time 915 855-6009. I think Phoenix Transmission might still do some S/P stuff http://www.phoenixtrans.com/IntlHome.html and possibly even Dacco http://www.daccoinc.com/. Here is PATC url also http://www.transmissioncenter.net/
All it takes is a phone call to find out.
P.A.E Enterprises, Inc.
4401 Turf Rd. Bldg E
El Paso, TX. 79938
915.855.6009
915.857.4727 -> Tech Line 8-10am and 4-5pm MST M-F
www.paeenterprises.com
Found this too but I doubt it will be much help, sorry
67Olds442X2
September 6th, 2011 06:12 AM
scrappie
April 3rd, 2008 06:41 PM
Fred H
January 24th, 2008 07:58 PM
SPEEDROCKET
December 18th, 2007 06:35 PM
Surfrat67
May 14th, 2006 03:42 PM
Quick Reply: Aftermarket torque converter...
