Champion Radiator, aluminum shroud, & electric fan - kit $359.98
Old August 4th, 2012, 11:21 PM
ah64pilot's Avatar
Anyone have any experience with the Champion radiators kit? I know the radiators are fantastic because I just put one in the 'vert...just wondered if anyone has their aluminum shroud and electric fans.
3 row radiator, aluminum shroud, 2-14" electric fans - $359.98
http://www.championradiators.com/page/458473582
ah64pilot is offline
Old August 5th, 2012, 02:08 AM
dancutlass's Avatar
Hey Steve, first of all thank you for mentioning that the radiator is great, because that's exactly what I wanted to know in another thread, I might buy one, too!
I don't have any first hand experience with the shroud and fans, but I didn't read a lot of good things about them, because the shroud blocks too much air to be effective!
Maybe this is a method to consider?!
http://www.cadvision.com/blanchas/54...FanShroud.html
Thanks again!
dancutlass is offline
Old August 5th, 2012, 05:46 AM
Insom's Avatar
No problems with the radiator. I didn't buy the the electric fan kit because after several hours of research the general consensus was that the fans are garbage.
Insom is offline
Old August 5th, 2012, 07:40 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I find the G body 3 core is barely big enough for my 403. The drain **** is in an ignorant spot and buggered up too. Go 4 core, if you do get one. I am thinking the Griffin Dominator, next time out.
olds 307 and 403 is online now
Old August 5th, 2012, 07:52 AM
Lt. Buzzkill (ret.)
copper128's Avatar
I found the same problem with the Summit-branded aftermarket aluminum radiator I used for my 67 442. The petcock hit the LH frame horn when the radiator was installed in the stock location. Even using a plug instead of a petcock wouldn't help because there wasn't enough room to get a wrench on it. So, I moved the mounts enough to the right that I could open the petcock. It was a PITA getting the fan shroud and top plate lined up then, so I had to slot some of the mounting holes. It all works fine now.
copper128 is offline
Old August 5th, 2012, 03:08 PM
ah64pilot's Avatar
That's what I have in the silver car right now and it's the same way. One of the tanks sits in the cradle but the other one is way off. I just put one of the Champion's I mentioned in my convertible and it fits great...
I know I'm gonna get a radiator from them but I was thinking about the fans too...but maybe not if they're not any good.
Old August 6th, 2012, 02:23 PM
70olds455's Avatar
What size champion radiator did you go with and what temperature does your engine run with it?
70olds455 is offline
Old August 6th, 2012, 09:44 PM
ah64pilot's Avatar
We put a 3 core in the convertible and it cruised for 200 miles with a 180 thermostat and never broke 190...with the A/C on the whole way. I think they are pretty good radiators and it fit in the factory location with a factory 4 core top plate.
Old August 7th, 2012, 03:47 AM
Aceshigh's Avatar
Agreed.
I have the 4 core Champion Radiator for my LS swap.
I'm not using their cheap low CFM fans they overcharge for.
I'm using a 90's Ford Taurus fan.
4000 cfm junkyard $40 fan baby. My write up on Nastyz28
that or the Ford Windstar fans are great inexpensive options you can get new for ~$80.
Aceshigh is offline
shamusj
January 13th, 2015 05:44 AM
Wedgewood Rod Shop
October 10th, 2014 06:00 PM
doggonn
August 11th, 2011 10:19 AM
ralsy
August 27th, 2010 01:07 AM
Quick Reply: Champion Radiator, aluminum shroud, & electric fan - kit $359.98
