Clutch failure
Old April 17th, 2024, 07:50 PM
Bernhard's Avatar
Clutch failure
Bernhard is offline
Old April 18th, 2024, 02:54 AM
SY2455's Avatar
Yikes, hopefully the driver wasn't hurt. It look like part of the input shaft is still in the clutch.
SY2455 is offline
Old April 18th, 2024, 07:01 AM
bccan's Avatar
I always hated dealing with the inconvenience of safety bellhousings, but boy, having toes can make it all seem worthwhile! Never mind the cost of repair.
bccan is offline
Old April 18th, 2024, 07:55 PM
BackInTheGame's Avatar
Holy Smokes!
BackInTheGame is offline
Old April 18th, 2024, 10:02 PM
Right?
Seen this many times over the years. Ask Don Prudhomme sometime about his opinion...
no1oldsfan is offline
Old April 19th, 2024, 06:52 AM
71 cutlass convertible
lshlsh2's Avatar
Looks like the aftermath of a Battlebots fight.
lshlsh2 is offline
Old April 20th, 2024, 01:58 AM
shiftbyear's Avatar
I hope the Dogtags hanging off the mirror weren't needed for identification.
shiftbyear is offline
Old April 21st, 2024, 05:16 AM
Right?
I believe it was Don Garlits. This is why Top Fuel cars are all rear engine now.
joe_padavano is offline
Old April 21st, 2024, 05:39 AM
OLDSter Ralph's Avatar
Joe P, I believe you are correct. There was a period when NHRA mandated grade 8 fasteners to help contain the catastrophic situations after the Garlits incident.. Oddly enough, NHRA went back to Grade 5 fasteners. The "findings" seemed to indicate that Grade 8 fasteners would shear and parts would separate......whereas Grade 5 fasteners would distort and bend without complete separation.
I was surprised at the results, because Grade 8 fasteners had a higher tensile strength than Grade 5.
OLDSter Ralph is offline
Old April 21st, 2024, 05:45 AM
The whole Grade 5 vs Grade 8 argument is clearly not made by engineers. As you correctly point out, the Gr 5 fastener has already broken before the Gr 8 even starts to yield.
Old April 23rd, 2024, 02:17 PM
The budget ALWAYS runs out at the flexplate!!
or flywheel!
Direct drum explosion. Turbo 400, TH350, and torqueflight transmission are known to do this for various reasons. This is why you NEVER downshift a transmission with a manual valve body and no engine breaking. People think nothing of spending 20k on an engine, but cringe at a 1000 aluminum direct drum. What are your feet worth? Or the damage to the car?
matt69olds is offline
Old April 23rd, 2024, 09:43 PM
Bernhard's Avatar
or flywheel!
Good point. It's not just flywheels and clutches that go bang.
Bernhard is offline
oldsmoboogie
November 28th, 2021 09:06 AM
442gs
June 30th, 2020 07:31 AM
Cincinnati Rick
August 3rd, 2015 07:08 PM
bummerino
April 27th, 2010 08:55 PM
mugzilla
September 7th, 2009 05:57 PM
Quick Reply: Clutch failure
