comp cams roller rockers 17044-16
Old February 28th, 2024, 02:07 AM
6844268's Avatar
i been in the process getting a new rebuild running, olds 400, i adjusted the preload per crane cams roller lifters, been sitting 2 weeks and went out to the shop to prime the engine and noticed 2 broken poly locks. crane says 1 1/4 - 1 1/2 turns then lock them down..what happened?
6844268 is offline
Old February 28th, 2024, 03:21 AM
fleming442's Avatar
I've only ever heard of 1/4- 1/2 turn past zero lash on hydraulic lifters. Either you misread, the instructions are wrong, or there's some new "technology".
Polylocks are tricky to adjust. It took me awhile to realize that the allen screw is a stop and not the lock. It's fun when you're dealing in thousandths on a solid lifter.
fleming442 is offline
Old February 28th, 2024, 04:51 AM
chadman's Avatar
A few things come to mind:
1) That is way too much preload
2) Do you have the correct length studs? How much of the set screw is above/below the top of the poly lock?
3) Are you overtightening them? They don't need to be cranked on like a head bolt.
Post pics to help us better understand what's going on.
chadman is online now
Old February 28th, 2024, 09:59 AM
OLDSter Ralph's Avatar
I think he is talking about setting the poly locks before start up. You are referring to setting the valve lash after valve clatter stopped on a running engine. The amount of turns after zero lash varies from person to person.
Personally, I set them at 1/8 to 1/4 turn, max. And I use internal snap rings in the lifters instead of the frail hairpins.
OLDSter Ralph is offline
Old February 28th, 2024, 11:01 AM
fleming442's Avatar
The lifter instructions tell you what the manufacturer recommends for preload.
The setup is the same regardless of "starting point". Use the EO/IC method, go to zero lash, then add recommended preload.
Old February 28th, 2024, 02:58 PM
Yes, manufacturers recommend the amount of preload. Hydraulic lifter preload is done more accurately after the engine has been started and is running. The problem with the OP is broken polylocks before starting the engine.
Old February 28th, 2024, 03:05 PM
6844268's Avatar
I just re-read the instructions, it says " up to" 1 1/4-1 1/2 Can be used due to the strength of these lifters....I'm dumber as I get older..
6844268 is offline
Old February 28th, 2024, 03:09 PM
6844268's Avatar
After zero lash they should be 1/2 - 3/4 turn then lock down. I misread my info.
6844268 is offline
Old February 28th, 2024, 03:11 PM
6844268's Avatar
U are correct on number 1. I read my instructions wrong
6844268 is offline
Old February 28th, 2024, 04:41 PM
cutlassefi's Avatar
Strength has nothing to do with it. It’s the valving and ultimately the amount of available travel in the lifter. I’d start at 3/4 or so and go from there.
cutlassefi is online now
Old February 28th, 2024, 04:58 PM
BillK's Avatar
Just want to add a vote to what Chad said in reply #3. Broken polylocks have nothing to do with lifter preload. Can you post a picture of where the Polylock broke ? You need to figure out why they broke. I usually crank down on them pretty good and have never had one break.
BillK is offline
Old March 30th, 2024, 02:46 AM
6844268's Avatar
this is the area where my pushrods are binding, pic isnt mine, my builder put on comp rollers 17044-16, 1.6, my heads are edelbrock performer rpm 61025, 3/8 pushrods. i was told these rockers are not for these heads? harland sharp makes a set for these heads. s5003. thoughts?
6844268 is offline
Old March 30th, 2024, 06:44 AM
Duh
Duh's Avatar
Don't use 5003, they don't fit that great especially with over 500 lift. The 5016 work well.
Duh is offline
Old March 30th, 2024, 07:41 AM
CANADIANOLDS's Avatar
this is where 3/8” P rods actually interfere with the body on the comp rockers..not up by the cup as shown in the pic. You’ll need 3/8” long taper P rods to work with the comps. you probably have standard taper P rods. Or you can grind the body of the rocker to clear the P rods you have now
The area of the black marker dot is where you need to clearance them.
when you initially did your 1 1/2 turns, at what point did you establish zero before doing the 1 1/2 turns?
CANADIANOLDS is offline
Old March 30th, 2024, 07:54 AM
Another thing. To me that pic of the blue rocker isn’t a fulcrum style adjustment.. it’s a P rod cup style adjustment and the adjuster is way to far up in the body which could be why there was contact on that one? The P rods could have been to long to start with
Old March 30th, 2024, 08:25 AM
6844268's Avatar
The area of the black marker dot is where you need to clearance them. backed out the set screws, 1/4 turn on the crank, and check them all, did this for 2 full revolutions then incorrectly gave them the 1 1/4-1 1/2 turns locked them down. So with the binding and over tightening the polys some broke. Should have done 1/2-3/4 turn...I might try to grind them for clearance
6844268 is offline
Old March 30th, 2024, 09:44 AM
yikes..I can’t even understand your explanation of how you did it wrong.
don’t make sense. If you actually turned the adjuster nut down 1 1/2 turns from zero lash, before even priming them, that shouldn’t bust an adjuster. The lifter plunger would just bottom out when rotating the cam.
it’s different if they were primed and pumped up, then you added the 1 1/2 turns….that may have caused valve spring bind when rotating the engine, and in turn, locked up the valve train and broke the adjuster
but they weren’t primed, correct?
are they short travel hyd roller lifters? What’s the lifter part#?
Old April 17th, 2024, 05:29 PM
6844268's Avatar
Crane 28532-16
6844268 is offline
Nemesis
May 10th, 2024 07:52 AM
MartinH
July 1st, 2022 04:30 AM
dfire25
May 1st, 2015 02:57 PM
morrowjm4154
May 20th, 2009 02:46 PM
Redog
August 14th, 2008 06:56 PM
Quick Reply: comp cams roller rockers 17044-16
