Dr. Dan's 478
#281
[QUOTE=Dan A. Macal;1315866]I have never ran any power adders on any of my stuff EVER. my 66 F 85 ran 9.60`s leaving from a dead idle 373 rear gear and I drove it to work several times. NO electronics, trans brake-NOTHING. When you get done with class racing, maybe you can graduate up to bracket racing. and if you think it`s easier than class racing....show up at the world footbrake challenge in Bristol TN in July. I bet you can`t get past 2 rounds. Everything I ever ever raced, I`ve won in. I just went through all my trophies moving. 296 total wins. 98 with 1 car. Ya know what.....you wouldn`t make it past 2nd round at a normal saturday night bracket race. I like class racing.....atleast until I found out you do it.[/QUOTE
Got it, what did you say that thing weighed? You could be right about the bracket racing, either I do very good or very bad. I don't claim to be a bracket racer, but I do drive and race 9 and 8 sec full weight small tire NA street cars, some with production GM engines. The NA race cars are faster
Can you post some pictures of this "66"
#283
#286
#287
The reason Bill didn't pull it lower is because if a person was to utilize the BT engine to its full potential it would never even see 4700 RPM on a run down the track, plus starting the pull higher would be easier on the mains.
#288
If you think peak tq occurred at 4500 you’re a bigger Dyno idiot than I thought. Unless you pull it beyond the initial high points you really don’t know everything you need to.
#297
This is a fantastic Olds engine. If only there were solid main 403 blocks. Dan's engine proves out what I was hoping for as far as potential of the hated 403. Is there a "light" version of Dan's 478 that started as a 403? I already have a nice 403 in my car, but looking to an upgrade, defiantly not to the extent Dan has done. Good heads, stroker crank, roller cam... I know the crank is a huge piece of the puzzle, but is there a way to keep the block in one piece? Care to share? Dan, Bill, Mark???
TIA
TIA
#298
TIA
TIA
#301
With a solid roller, .776” lift
#302
I guess I need to ask Bill about the billet piece $$$ for another.
Keep up the good work.
Edit: We do have two 5 axis CNC and 1 three axis CNC milling centers at work now.
#303
TIA
TIA
#304
At some time we need to have to get together for a beer or three. I may move to Florida at some point. State of ILL is just that. ILL. Im looking north of you though. We need to talk...
#305
thinks to do in Illannoy- leave
#307
#308
But how would you know that unless you pulled it down that far. You throw out the first and last couple of numbers anyway.
