Halo girdle
#41
#42
#43
Thanks for showing us. I also notice your freeze plugs are square as well, I guess that comes with good machine work.
#45
Couple of questions, straps do the caps get milled just enough to be flat? Not absolutely necessary but recommended. I actually just dust them on a surface grinder. What studs are used? And in regards to the halo isn’t the halo just a tied to gather strap system in a sense? In my opinion yes, that is all that it is. No better, no worse. Just more expensive and complex to install correctly.
#46
This build is in another league. Max HP & TQ build that required a well thought out bottom end support.
When I think of the halo, or straps its in the 500 HP max entry level HP build.
#47
I am working on my 403 build. If I have a mild cam, 9.0 compression with 7a heads, and cast pistons, I think I am looking at 325hp ish at 5200. Do I need to do any bottom end mods at this power or RPM on a 403? When do you need a girdle? 6000? 7000? I know these are heavy pistons. Would there be any benefit from balancing the reciprocating assembly? I previously had it done on a 350, and the engine builder said it wouldn't hurt anything but not necessary unless I was going 6500+.
#48
#51
Depends on who you ask- some say it does absolutely nothing and some say it helps keep the caps from walking around.
I have one, and the caps showed signs of walking, so maybe it does nothing.
#53
Except you are not boxing the frame! You are boxing the main caps. The weak spots are the webs. It can help somewhat but what difference does it make when the webs are not being reinforced. The only good solution is to be tied to the block like chadmans girdle.
#54
That is exactly what I was trying to do. I installed my hallo without milling caps 1 thru 4. I can't see that it doesn't help. This is not a 600 ho + build. So I think it will help and certainly won't hurt. If I was to build a motor such as chadman's, I would certainly use a girdle. A girdle is the only option for high HP/TQ. The HP/ TQ in my build does not warrant a girdle and the cost of one.
#55
#56
I did this to a customers engine only because he had already bought the parts. It痴 a stock type build so I just cut the caps enough to install the halo under the straps. Didn稚 have to clearance the pan either.
in the end it would have been less to get four billet caps ..either way it痴 getting line honed and labour
#57
Chadman, where did you source the girdle and parts? Can't find Jeff on the internet
#59
Jeff Smith is no longer around. He passed away a few years back. BTR stopped making his girdle as well due to the new RR block being available. If you are looking to make serious power the RR block is by far the best option. By the time you have a full girdle made and pay to have it installed correctly you are a good ways toward the purchase price of a RR block.
