J headed 350 olds
J headed 350 olds
So got the car out with the new engine. Ported J heads , Rpm intake, 750 carb , Engle solid lifter cam 560 ish lift 245 ish duration I wanna say. 10.25 to 1 compression, speed pro pistons , nothing fancy. First pass with mufflers ran an 11.82 @110 . Uncorked the exhaust changed the timing set the shift point to kill and it ran an 11.58 @ 113. This combo has more in it.
https://youtu.be/hZT2QXF0eOE
James71Cutlass
December 10th, 2021 03:12 AM
