Let’s Build A Turbo Small Block
#42
I received another piece of the puzzle today. It’s a Forced Performance HD 80/85 T6 turbo. I also called BTR and he is hoping to have bearing spacers in a few weeks. I’m hoping to start machine work on the block by the beginning of the year.
#46
Glad to see you're making progress. I'm curious how you decided on that 80/85 rotor group? It might be a little small for your build. That is, you'll have to wastegate early so as not to overspeed the turbo. If that engine breathes as well as it sounds like it's going to, you could take advantage of larger comp and turbine wheels.
#48
#49
It is a 3 5/8 inch stroke crank. We have not got to what cam I will use yet. I am thinking about using the solid roller that is in my 461 currently. I plan on calling Bullet cams and talking with them about possible cam specs. My machinist is looking at rod and piston combos to give me a few options. We are shooting for 9:5:1-10:1 compression.
#50
Boogie, I think you went a bit big on turbo and a little to high on compression goal? I posted a reply but it went to the wrong thread:
https://classicoldsmobile.com/forums...-build-167137/
I would use this On3 turbo that is a 76 and will support 1125Hp
https://www.on3performance.com/shop/...harger-1035hp/
And look at Frozen Boost for intercooles and stuff:
https://www.frozenboost.com/
#51
Boogie, I think you went a bit big on turbo and a little to high on compression goal? I posted a reply but it went to the wrong thread: https://classicoldsmobile.com/forums...-build-167137/ I would use this On3 turbo that is a 76 and will support 1125Hp https://www.on3performance.com/shop/...harger-1035hp/ And look at Frozen Boost for intercooles and stuff: https://www.frozenboost.com/
#52
what we find, on street motors is that lower compression works better and move forgiving to parts and tune. 8.0 is more forgiving tune than 10 to 1. And if the turbo is only going to support roughly X amount of power anyway, one runs better with street stuff with lower comp and bringing in the boost to compensate. But there are TONS of ways to go and most will get to the same or close results.
MOST of the guys I know on these mild builds, (MILD PARTS WISE) usually make 1000+Hp with 75 mm stuff for street drivers. These are usually 8 second, 3400 lbs or more that are pump gas.
#56
I picked up another block, 4 bolt main caps, and bearing spacers from 68 Post over the weekend. I got them dropped off at the machine shop, they are pretty backed up but he is going to fit me in. I am hoping to have the engine back in April. Until then I will keep working on the headers and hot side turbo piping.
#57
#58
#59
See this is why don't come here any more lol. Non sense. Oldsmoboogie there is a guy in your area running a very fast boosted olds ( pro charger ) nice guy but he ain't much on the Internet. I remember when guys told me my engine would blow up. Here I am running 11.50's 200 + 1/4 mile passes and 3k street miles with parts no one would ever use because " why risk it "
#60
#62
I haven’t decided on fuel yet. I’m leaning towards e85 and non inter cooled. I am waiting to hear back from the machine shop on some piston choices to determine compression ratio. I have 2 waste gates, 1 for each bank.
#63
What is your final bore size ? If he has it cleaned and machined lets see those block pics !
#65
What EFI do you want to use? 8 injectors in the manifold or just a throttle body EFI like the 1200HP (=800HP on E85) from FiTech of Snipper?
2 wastegates sounds like more then enough to control the boost.
#66
I will most likely use an elbow and ls style throttle body with injectors in the intake. I have some 3/16’s aluminum sheet so I am going to talk to my buddy about building a sheet metal intake similar to the Holley low ram intakes. It all depends on how busy he is and what he will charge for it. If he can do it for 1,000 or less I will go that route.
#67
Cool project! Boost is very addictive. There has been a lot of great advice already so I don’t have much to add... with turbos the easy part is making the power, the hard part is making the trans, rear ends, etc all live.
#69
A few updates to post, unfortunately i have not heard back from the machine shop in a while. I am hoping to have the engine back by the end of April, I know he is swamped so I am trying to not bug him. I did get a Victor intake, Summit has them again. I got the passenger manifold tacked up and turbo placement figured out. I am fitting and tacking everything and my buddy that is a pipe fitter is going to weld everything together. I am going to convert to a manual rack to eliminate the steering box and pump. I will need to figure out a passenger side alternator set up.
#70
That is looking good!!
Do you want to make a support bracket for the turbocharger (like the V8TV build) or have the complete weight of the turbo on the manifold?
Take your time to get everything positioned correctly, install all the components like radiator, alternator, etc. before starting on the pipe routing.
The wastegates can become a bit difficult sometimes but it depends on if you want to have them open or routed back into the exhaust system.
On my racecar I moved the alternator from the passenger to the driver side and changed it to a small 40A unit from a Kubota digger.
#74
I stopped by the machine shop this week and they have not started on the machine yet unfortunately. I did get the manual rack installed though. Now I can finish the drivers side header and hot side mock up.
