Olds 455 Build
Old August 20th, 2022, 04:07 PM
Chris
Chris K's Avatar
Olds 455 Build
Hi All!
I ended up picking up a 455 block for my cutlass here last fall. I’d like to get it build by the end of winter if possible, this would be my first time building a v8, but I messed with plenty of old Honda motorcycles rebuilding em. I’ll get all the specs for the motor later on tonight! Any help and I’m sure advice while assembling will be greatly appreciated! I’d like to do it right the first time. Keep in touch! Thanks!! Plan on 500hp if possible!
Chris K is offline
Old August 20th, 2022, 04:35 PM
75 W-30 H/O's Avatar
This is a good read if you don't already have it...
75 W-30 H/O is offline
Old August 20th, 2022, 04:40 PM
https://www.ebay.com/itm/17499870941...mis&media=COPY
Old August 20th, 2022, 05:53 PM
cutlassefi's Avatar
Budget?
cutlassefi is offline
Old August 20th, 2022, 07:14 PM
Chris
Chris K's Avatar
Have one of those on order!
Chris K is offline
Old August 20th, 2022, 07:16 PM
Chris
Chris K's Avatar
Budget?
Not really concerned, if it’s something that will need done, it can wait till I get it!
Chris K is offline
Old August 20th, 2022, 07:34 PM
Chris
Chris K's Avatar
Here’s What I Got So Far.
455 block bored .030 over
Keith Black Pistons 227-030
Stock rods
Moroso 7QT Pan and Melling HV Pump
Comp Cam 42-236-4 292 .518 Lift
Comp Double Roller Chain
Main Bearings and caps and such.
Now Questions!
Aluminum Heads?
Intake?
Oil Restrictors?
Im open for all ears on stuff
Chris K is offline
Old August 20th, 2022, 07:48 PM
Aftermarket rods without a doubt. The stock rods leave much to be desired.
matt69olds is offline
Old August 20th, 2022, 07:50 PM
Chris
Chris K's Avatar
What would you recommend?
Chris K is offline
Old August 20th, 2022, 08:34 PM
cutlassefi's Avatar
Is 500hp the threshold or what would you “settle” for?
Old August 21st, 2022, 06:53 AM
New2oldsw30's Avatar
Chris, I'm in process as well of gathering parts for a similar build, but more in the 550/575Hp range. So will be following close, as with all builds or threads with similar info.
Check out these threads:
https://classicoldsmobile.com/forums...ngines-162087/
https://classicoldsmobile.com/forums...stings-139727/
I have another one CutlassEFI Mark was involved that was like 496Hp.
I would just go with Speedmaster heads and source them from Mark CutlassEFI. 500Hp is very doable. Mark like Performer intakes but I'm using a Torker but going tomport a Performer and compare both. Get the heads bare and have Mark fill them and get you the cam and intake.
New2oldsw30 is offline
Old August 21st, 2022, 09:16 AM
Chris
Chris K's Avatar
It’s gonna be a street car, basically take it to cruises and the occasional run it down the strip for a time or two. I’d like to shoot for that ball park if possible. Going in a 71 Supreme, intentions of making look stock. Need to change my rear gear also, right now a 3.08
Chris K is offline
Old August 21st, 2022, 12:38 PM
cutlassefi's Avatar
So I’m guessing you’ll be sticking with irons then?
If so then you’ll need them ported to some degree. Nothing crazy, but more than stock trim.
And I believe you meant a KB 277 piston? Not the best but it’ll work in your combo.
Next would be compression and cam. Around 10-10.25:1 and something in the high 230’s-240’s @.050 will help get you there as well.
Best of luck in your build, let me know if I can be of help.
Thanks.
Old August 21st, 2022, 04:29 PM
Chris
Chris K's Avatar
Thanks.
Gonna send you a pm or you by chance have messenger??
Chris K is offline
Old August 21st, 2022, 04:41 PM
cutlassefi's Avatar
PM is fine. We can email from there. Thanks.
Old August 21st, 2022, 05:55 PM
Bernhard's Avatar
I would invest in a good aftermarket rod and Piston. Mark sells a quality piston with a modern ring pack its a good value IMO.
Bernhard is offline
camdon454
December 22nd, 2014 11:00 AM
billmerbach
December 11th, 2014 05:03 PM
rootney
July 27th, 2014 04:24 PM
Stevec
February 6th, 2014 02:18 PM
projectheaven
November 28th, 2008 07:16 AM
Quick Reply: Olds 455 Build
