Olds type "O" rear end gears
Old May 13th, 2014, 10:35 AM
val1550's Avatar
I have a set of Richmond 4.10 gears for a type O rear end for sale. Apparently Richmond is months behind on production for the type O rear end, and I have no use for these. If anyone is interested please message me. I also have the posi carrier for the type O but it does need to be rebuilt. Make me a good offer and its yours. Thanks.
val1550 is offline
Old May 13th, 2014, 10:49 AM
Engine Builder
Smitty275's Avatar
I don't think Richmond has made a gear set for a type O in a decade or better. Can't believe they ever will. Wish I had a use for them. Type O rears are good stuff.
Smitty275 is offline
Old May 13th, 2014, 11:02 AM
Trying to remember member
wmachine's Avatar
Are they the type that fit the 3.23 carrier? Or the stock type that fit the 3.42+ carrier?
wmachine is offline
Old May 13th, 2014, 12:36 PM
val1550's Avatar
gears
The carrier is stamped with 588 if somehow you can tell which carrier that is and the gears are stamped right from Richmond. I do know that it is a type o rearend because I also have the entire housing.
val1550 is offline
Old May 13th, 2014, 02:17 PM
Magna86's Avatar
PM sent
Magna86 is offline
Old May 13th, 2014, 02:32 PM
BackInTheGame's Avatar
588 carrier
The 588 carrier is the "big" one for the numerically higher gears (3.42 and up). IIRC from a conversation with Bryan Trick last year, the Richmond ring gear will need to be milled .010" on the back side to fit properly. Double-check with the rear-end specialists on here before cutting, LOL!
BackInTheGame is offline
airvegas
July 12th, 2015 07:38 AM
350TurBRO
September 12th, 2014 11:52 AM
val1550
May 3rd, 2014 10:00 PM
L77F85
Drivetrain/Differentials
16
November 29th, 2013 06:19 AM
goatwgn
December 28th, 2012 08:28 AM
Quick Reply: Olds type "O" rear end gears
