Powerglide transmission
Okay what I need to understand is this powerglide has a turbo 400 Shaft for the converter. What if anything should I be concerned about?
You need to find out if the transmission has a stator bushing. If not the converter has to be set up for it. A bushing can also be installed in the transmission if the shaft will support it. If the transmission has a bushing any turbo converter will work. Most quality converters have a support bushing but check with the manufacturer.
dougandarthur
November 18th, 2021 03:51 PM
