For those that used to frequent Realoldspower
I quit posting there but drop in every now and then just to lurk. It's still the same cesspool it was with the same guys. There are a couple of good guys there tho. I wonder if Steve 81 & no1olds are the same person?
That site used to be a lot of fun back in the day (10-15 years ago). There was also a lot of good technical info on that site. A couple of back-to-back hacks really did that place in. It's too bad that all of that info wasn't backed up.
I agree.
There was a good base of Oldsmobile racers that would share their hard earned knowledge.
then the Karen’s came along and said “hey, you can’t say that or do that because it hurts feelings” Shoot, this place used to gossip all the time about how mean and nasty ROP was,, it actually scared guys on here
no fun allowed , online or in person.
and with all the fighting and hatred, we still all got together at Norwalk every year for the best Olds race , car show and swap meet ever.
I always thought ROP was at it's best when it was allowed to self govern.
When Andy would have one of his customers share their experience / give customer feed back. He would spam the thread until it became locked or removed. I think it would have been better to have it just play out / self govern.
The crashes did not help the site and I'm not sure if all the content was recovered after every crash?
Paul had a way with words
just kidding 😜
Years ago on ROP I came up with a formula to compare na cars. It included weight, cubic inches, et and or mph? and have you a number ..I can’t remember exactly…but your number was your place on list.
anyone remember that?
it worked. It kinda took out all the bs. At Norwalk the weight was proven. It shut up a lot of the posers
should do it again
should do it again
should do it again
should do it again
3810lb
468
11.42@121
should do it again
should do it again
I kinda remember that. It took Andy Millers "Potato chip" car way down the list.
I also remember REALLY wanting to be on that list. By the time I was running fast enough to be on it, the guy would never add me.
Who kept that list?
Who kept that list?
Here is the Classic Oldsmobile version it has not been updated in a while.
https://classicoldsmobile.com/forums...ference-93886/
yep, it knocked his dragster wayyyy down the list
The old Kings of Olds power list only took one thing in to account, which was ET. The list should have been called Kings of ET.
this formula takes all four factors into account when making power comparisons between cars. Any of the four inputs can be changed , weight , cubic inches , ET or MPH which will change the final score, up or down. It works as any single change that will give you a better(Lower PFS#) score , like being heavier, having less cubes, higher MPH or lower ET, than an identical car …and vice versa for a worse score.
A= race weight with driver/ET
B= cubic inches/A
PFS= B/MPH x 1,000
The lower the Power Factor Score is, the higher you are on the list.
B= cubic inches/A
PFS= B/MPH x 1,000
B= cubic inches/A
PFS= B/MPH x 1,000
B= cubic inches/A
PFS= B/MPH x 1,000
Old combo:
462 CID
9.19 @ 141.38 mph
3170 lbs.
PFS score = 9.47
Wallace calculator HP based on ET 808 HP/462 CID = 1.7489 HP per CID
New combo:
529 CID
8.75 @151.5 mph
3215 lbs.
PFS score = 9.50
Wallace calculator HP based on ET 950 HP/529 CID = 1.7958 HP per CID
ET-MPH-HP Calculator (wallaceracing.com)
#31
This is fun to play with but I have to question it's accuracy as a litmus test for ranking. Just for fun I plugged in my old combo in comparison to my new combo. According to the PFS calculation my old combination scores better. When plugging ET numbers only into the Wallace calculator (attached) the new combo scores better on a HP per CID basis.
Old combo:
462 CID
9.19 @ 141.38 mph
3170 lbs.
PFS score = 9.47
New combo:
529 CID
8.75 @151.5 mph
3215 lbs.
PFS score = 9.50
Old combo:
462 CID
9.19 @ 141.38 mph
3170 lbs.
PFS score = 9.47
New combo:
529 CID
8.75 @151.5 mph
3215 lbs.
PFS score = 9.50
Do you think your new combo is done already as far as not running quicker or faster? I inputted an increase of just 1 mph…..your PFS dropped to 9.44
what gave your old combo such a good score was it had 67 fewer cubes , but was only 45 lbs lighter.
another thing is the difference between 9.5 and 9.47 isn’t that much before rounding it off and multiplying it by 1,000.
Before; new combo exactly .0095, old one .0094735 which is only .0000265 diff
#32
#34
Wallace numbers are all based on sea level. Unless both your old combo and new combo were run under identical conditions to get your numbers, it’s hard to be exact.
I do think the new combo has more in it yet. The best with the old combo was also in better air, under 500ft. The new combo was around 1,100 ft.
#35
#36
Pretty sure I'm done. I've already started on upgrades for next year. Gonna try to get a little more weight out of it and get a chute on it. I was getting a little nervous going 150mph without one.
#37
Also when I made this list my car weigh was with me in the car. So car weight with driver, engine,Et,mph . I think that covered it. So then it can be plugged in to Wallace calculator for most information. Nothing stopping anyone from adding a new list ! Me I tried but not enough wanted to add their cars or up date. Same thing happened with racing engine combo forum lack participation! So carry on .
#38
I think tester has ! Maybe not with a Oldsmobile engine.
#39
where is your car on the kings of Olds power list?
#40
