Ultimate siamesse nascar sbo
I know some here are watching - following Kevin Smith (Soccermom) Siamese NASCAR block. I think everyone should know this all-out SBO engine build. Facebook Oldsmobile Max Performance BTR
Water in both the heads and the block, but separate from one another on the deck surface,
Facebook Post
Facebook Post
Interesting, thanks for posting.
Why do they separate the cooling system between the heads and block, what is the advantage? Are the grooves in the deck around each cylinder for better sealing and a different design head gasket?
Regarding the grooves and rings, this article was in the NMCA magazine a while back, explains it pretty well: https://www.racepagesdigital.com/blo...plication/2769
[QUOTE=fleming442;1412112]For some reason, I thought soccer mom (blue Camaro?) was turbo LS? I don't cyberstalk KSR, but they do pop up in my IG feed....[/QUOTE
I believe he keep blowing up the LS.. Has BTR building this one for him. Siamese Nascar sbo
Kevin has been an Olds guy forever, he was on ROP back in the day (15-20 years ago) when all the fast Olds guys were on there, his '78 cutlass hauled *** with a 350 gas block combo. Pretty sure this new engine that Bill is building is for that car, it's been in the works for a long time.
JOHNNYOLDS442
July 5th, 2020 08:03 PM
