What Torque? - McLeod and ARP
Old February 7th, 2024, 02:09 PM
VI Cutty's Avatar
I'm installing a McLeod "11 inch Super Street Pro" pressure plate and clutch disc with ARP hardware. The McLeod instructions indicate a 35 ft/lb torque on the 3/8" bolts while the ARP instructions for their bolts call for 45 ft/lbs. Should I use the McLeod specs or ARP's?
VI Cutty is offline
Old February 7th, 2024, 05:10 PM
fleming442's Avatar
I'm pretty sure 35 is standard for 3/8 hardware and also the FSM spec. I can't tell you if 10 will make a difference one way or the other.
fleming442 is offline
Old February 7th, 2024, 07:02 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
10ft/lb isn't ****. Do 45lb/ft per ARP with blue loctite on clean threads.
droldsmorland is offline
Old February 8th, 2024, 08:16 AM
BillK's Avatar
If you are using ARP bolts then use their torque specs with whatever lube or thread locker they recommend. When you torque a bolt you are actually stretching it almost like a spring. Different materials need different torque to get the correct stretch.
And no matter what anybody says, 10 ft lbs can make a difference. Sometimes a lot sometimes not but the point is if a fastener manufacturer gives you a torque or stretch specification that is what you need to go by.
BillK is offline
Old February 17th, 2024, 02:44 AM
asaz1's Avatar
Step into the digital world with webcam vector These versatile tools for online communication have become essential in today's interconnected society. Illustrating webcams in vector art allows for dynamic representation, capturing the sleek design and functionality of these devices. Whether for virtual meetings, live streaming, or content creation, webcam vectors offer flexibility in design, enabling customization to match various platforms and aesthetics. Dive into the world of digital communication and express your creativity with webcam vectors. From minimalist designs to detailed renderings, let your imagination take center stage as you showcase the importance and ubiquity of webcams in our modern lives.
I would recommend using the McLeod specs for the 3/8" bolts, as they are specific to the pressure plate and clutch disc that you are installing. The ARP specs are more general and may not account for the exact fit and alignment of the McLeod components. Using the higher torque value of 45 ft/lbs could cause excessive stress or distortion on the pressure plate, which could affect its performance and durability. Therefore, I think it is safer and more reliable to use the lower torque value of 35 ft/lbs, as suggested by the manufacturer of the clutch kit.
asaz1 is offline
Old February 17th, 2024, 08:50 AM
OLDSter Ralph's Avatar
Originally Posted by billk
if you are using arp bolts then use their torque specs with whatever lube or thread locker they recommend. When you torque a bolt you are actually stretching it almost like a spring. Different materials need different torque to get the correct stretch.
x 2
OLDSter Ralph is online now
Old February 17th, 2024, 12:36 PM
VI Cutty's Avatar
Following up, I used the ARP recommended torque. I figure the properties of the bolt would determine the correct torque for proper performance.
VI Cutty is offline
MO Olds 2022
July 14th, 2022 12:16 PM
OldOldsLover
March 21st, 2022 08:04 AM
oilcanman
February 22nd, 2022 02:49 AM
major tom
August 13th, 2010 10:04 AM
al_gohi
December 18th, 2006 02:24 PM
Quick Reply: What Torque? - McLeod and ARP
