who has 45 degree cams for sale
I'm not 100% on the blocks, but the early ones- 330 and 425s have a 45⁰ lifter angle requiring a cam ground to fit. Most later Olds are 39⁰.
1964,65,66 330 motors are 45 degree cam; 1967 330 motors are 39 degree. 1966 and 1967 400 motors, 1966 and 1967 Toronado motors and all 1967 425 motors are 39 degree cam; other 1965 and 1966 425 motors are 45 degree as well as 1965 400 motors. All 1968 and newer motors regardless of displacement are 39 degree. Regarding water pumps there are at least 3 different water pump lengths used throughout the years and models and one specific with the inlet on opposite side used only on 1964 330 motor.
You can also talk to Mark Remmel (cutlassefi). He had one in stock that fit my application when I was building my 425. You never know what he'll have laying around. He'll also be able to get one ground for you if he doesn't have one laying around.
For water pumps, the 1970-older engines had larger hose nipples on the water pump and radiator lower hose. The size of the those fittings changed in 1971 to a smaller diameter. So if you buy a newer water pump for an older engine, you need an adapter to get the lower radiator hose to fit.
Then as noted, there were three different snout lengths for the different applications (AC, non-AC, and I don't remember the third).
39 degree not 45
Last edited by oldsnmopar; November 28th, 2022 at 08:14 AM. Reason: I had wrong info
Hi. Yes, it's the 1966 E 400 in my 66 442. It's bone stock, but I want to upgrade cam now, since I have it out, and resealing it. I want a modern cam that will work well with the tri carbs, 4 speed and 3.90 gears.
39 degree
you know, that's what I thought. But then I was reading another post on here that I actually replied to I think, that said they're 45s and all the other ones are 39. I thought they were backwards but I wasn't sure. It's been too long. This is only my second one. I had a 67 in high school.
39 cam
I am interested in information.
Richshull@hotmail.com is my address if you would be so kind to send me some info please.
