Best oil pan gasket sealer?
Old March 18th, 2011, 10:07 AM
In replacing an oil pan gasket that is only available in cork, what is the best way to seal it for many years to come?
Cork valve cover gaskets have given me too many fits over the years and glad the rubber ones came to be.
No rubber oil pan gaskets can be had though for my application though.
Is it better to seal the cork with something like Permatex or loose the cork completly and just use a bead of RTV?
Old March 18th, 2011, 10:19 AM
I've always used Permatex High Tack on the cork gaskets and have never had any problems.
I used the stuff on head gaskets in my youth, it didn't hurt anything.
Old March 18th, 2011, 10:59 AM
cutlassjoe's Avatar
On a different note but along the same lines how about tips on the trans pan gasket. I finished my resto, and the trans pan is dripping from the front. It is a new gasket, and I don't think they used any type of a sealer. Does any one have any tips. I have a new gasket and I am thinking of changing it this weekend. Thanks.
cutlassjoe is offline
Old March 20th, 2011, 12:00 AM
jpaulwhite's Avatar
I've had good luck with spray gasket in an aerosol can. The can was blue and white. The actual gasket material was red.
jpaulwhite is offline
Old March 20th, 2011, 07:00 AM
On both trans and engine pan gaskets, I've had good luck with both permatex and auto silicone.
Just wipe the pan with a thin coat and install the gasket, let dry, and install on a clean surface, which I usually wipe with some kind of grease so the gasket doesn't stick. [for the next time/guy]
Same way for valve cover gaskets.
Just make sure all the holes and pan itself isn't distorted by 'overtightening'.
Old March 20th, 2011, 09:26 AM
I never even thought of just using on one side, figuring it would leak that way.
I guess as long as I do not overtorque and the pan seal surface is flat it it will be okay...
Want to do this right the first time, as there will not be another round.
Old March 20th, 2011, 09:29 AM
X2 on this. I have used it for years and never had a failure
Old March 20th, 2011, 09:43 AM
On one side of the gasket or both?
Old March 20th, 2011, 09:51 AM
I use it on both
Old March 20th, 2011, 10:10 AM
greenslade's Avatar
try a spray adhesive like bd1185 we used it on cummins oil pan cork gaskets,spray it on the pan and set the gasket on pan then spray the gasket before installing on eng.it tack up fast so.and works well
greenslade is offline
Old March 20th, 2011, 10:34 AM
Right or wrong, my reasoning for grease on the machined part is to keep the cork gasket from drying out and ease of removal, next time.
Permatex or silicone will position the gasket and seal it to the 'tin, bendable' part.
Since machined flat, what's sealer gonna help?
With grease, you've only one side to clean if it comes apart again.
Old March 20th, 2011, 12:48 PM
Nor Cal Andy's Avatar
I have used a gasket sealer called Gaskacinch. The same stuff that Edelbrock sells. It is sold here in California I think you can get it other places through Summit or Jegs. I have used it for ever my Dad has used it on cork gaskets for 50+ years and it worked great but you have to let it tack up.. Its also referred to as Monkey Snot.. LOL I coat the metal surfaces and the gasket separately let it tack up for 5-10 min then put them together and I havent had leaks on anything..
Andy
Nor Cal Andy is offline
Old March 20th, 2011, 02:01 PM
One of None W-31
71 Cutlass's Avatar
X3
Also, in reference to the trans question. I stopped using cork trans gaskets long ago and have never has an issue with the newer rubber type (I get the whole kit with filter etc. from the local NAPA store). Also, if your trans pan is not TOTALLY flat all the way around, sometimes that is why it leaks in only one place(that spot may be bent causing a low spot for trans fluid to leak out).
71 Cutlass is offline
Old March 25th, 2011, 10:10 AM
jpaulwhite's Avatar
Exactly how I do it!
Old March 25th, 2011, 07:00 PM
Boldsmobile's Avatar
Have you ever checked out the diesel pan gasket?
http://72.22.90.30/phpBB2/viewtopic....sel+pan+gasket
Boldsmobile is offline
Old March 26th, 2011, 08:49 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
SCE makes a 3 rubber pan gasket set. Corteco and Milidon makes fiber pan gaskets.
olds 307 and 403 is offline
Old March 31st, 2011, 04:11 PM
Bayou Olds's Avatar
I use it on both
Ditto. I am a true Permatex believer.
Bayou Olds is offline
Old April 1st, 2011, 05:13 AM
Looks like I will do permatex, since I have that and the cork gasket already.
I will keep my fingers crossed.
If it leaks, the motor is NOT coming out again.....
Sampson
April 19th, 2013 09:27 PM
Sampson
April 18th, 2013 06:06 PM
bluecab
Body work
March 6th, 2012 06:51 AM
bluecab
Body work
October 5th, 2011 06:22 PM
dallasite21
June 20th, 2010 05:37 AM
Quick Reply: Best oil pan gasket sealer?
