Wipers quit in the rain
Old September 30th, 2011, 10:12 PM
car_designer's Avatar
Driving home tonite in the rain after dark, the windshield wipers on my '83 Delta 88 quit working.
The electrical connector for the wiper motor seemed well connected. I then pulled the fuse and it looks ok. I also checked the ground strap and it seems connected at both ends.
Until today, they were working fine.
Before they quit working, I had noticed, a few times, that when I was using the momentary mode (mist mode?, not washer) when I would release the switch mid-sweep, the wipers would hesitate a little (pause mid-sweep for a fraction of a second). When they quit, I was again using that mode, and when I let go, they stopped where they were. I do not know what I did, but I did manage to get them to rest in the park position, but then I could not get them to turn on again.
I noticed when I tried turning them on (either low speed or mist mode) that I heard a click from around the wiper motor, but nothing moved.
Any suggestions what to check next or what the problem might be?
car_designer is offline
Old October 1st, 2011, 02:47 AM
Yellowstatue's Avatar
Could be the switch itself...put 12 volts directly to the motor and see what the result is...
Yellowstatue is offline
Old October 1st, 2011, 06:30 AM
Or check for 12V at the connector with the sswitch on.
Old October 3rd, 2011, 07:54 AM
I have the same problem with my 84. Pull the connectors off the wiper motor and clean the contacts on both sides. Use a contact cleaner spray. The early 1980s GM cars used some of the lowest quality electrical connectors I have ever seen. My 84 is as bad as some British cars for electrical problems, melted connectors, etc.
Old October 3rd, 2011, 03:42 PM
Did the testing procedure found in the body service manual to test the switch at the motor connection end and everything did what it should, so it looks like the problem is the wiper motor.
Bobac455
August 27th, 2011 03:20 PM
knighthawk
July 22nd, 2011 09:11 PM
1971 442 convert
July 7th, 2011 08:11 AM
Jaybird
September 22nd, 2010 08:00 AM
FTW65W29
February 7th, 2010 10:02 AM
Quick Reply: Wipers quit in the rain
