Ralley Pak gas gage quit working
Old July 22nd, 2011, 03:19 PM
knighthawk's Avatar
Location: from Wisc, then Texas, then Kansas, now back to Texas,
all gages have been working fine, now I noticed the fuel gage always goes up beyound full. I think that means it's grounded, so even when I unhook the leads in the trunk, it still goes to full, QUESTION; where do I check it under the dash ? If I remember, it has a flat multiple connector....so.... what's the best way here ? which one is power ? which one is the ground or sender ?
knighthawk is offline
Old July 22nd, 2011, 03:22 PM
Lady72nRob71's Avatar
If the sender line is open, gauge will read past full.
Short the tan gas gauge wire to ground in the trunk and see if it goes to empty. If it does, then either the sending unit is not making good ground, OR the sender itself is bad.
Lady72nRob71 is offline
Old July 22nd, 2011, 05:37 PM
knighthawk's Avatar
shorting it to ground akes no difference, still reads full....so.... the wire to the sender is open somewhere ? which wire at the gage can I ground ?
Old July 22nd, 2011, 07:57 PM
Sure sounds like it.
Pull the gauge and ground the tan one right at the connector (without disconnecting anything), assuming this is a 70-72 A body. You may need a very thin stiff wire to get in there around the tan wire. It is between the gray and blue - it has NO white stripe.
Here is a reference picture:
Old July 22nd, 2011, 08:50 PM
knighthawk's Avatar
actually a '69 Cutlass S , I should have said so . wire colors should be the same ?
Old July 22nd, 2011, 08:54 PM
knighthawk's Avatar
can I reach up in there and ground the tan wire without pulling the gage to unplug it , ?? with a paper clip or something ?
Old July 22nd, 2011, 08:58 PM
I think with the 69 the gauges come out the bottom. I do not knowany more than that. The wire colors and positions may vary also.
Old July 22nd, 2011, 09:11 PM
knighthawk's Avatar
the gages DO come out the top, and I 'think' the wires were in differnt slots, but the same color...............I'll see tonite, .....thanks
tds
July 1st, 2014 09:30 AM
weasel
February 1st, 2013 10:15 PM
1PDQ55
January 18th, 2012 06:47 PM
knighthawk
February 4th, 2011 01:03 PM
GoBigRed
June 7th, 2008 06:17 AM
Quick Reply: Ralley Pak gas gage quit working
