Flexplate interchange for 455
Old December 5th, 2012, 08:20 PM
csouth's Avatar
Forgive me if this is a stupid question, but will a Pontiac Flexplate interchange with an Olds 455? I'm asking because I'm trying to use the convertor I have with the 4L80 I picked up while I test and tune the car. I thought with the Pontiac having the 6 pad flexplate it would help a great deal. I'm going to have a convertor built, but the won't be right away.
csouth is offline
Old December 5th, 2012, 09:12 PM
ah64pilot's Avatar
I can't answer your question but it would help if you had an Olds flexplate to compare it to. Remember, it is more than just seeing if the bolts line up. The flexpate is counter balanced to the engine rotating assembly, so if the weights are in a different spot or are heavier on one side it won't work.
ah64pilot is offline
Old December 6th, 2012, 04:19 AM
chadman's Avatar
No, you need a 68 and up Olds flexplate.
chadman is offline
Old December 6th, 2012, 07:43 AM
csouth's Avatar
OK, thanks. I already have one of those. I think I'll move my converter up in my list of priorities.
csouth is offline
Old December 6th, 2012, 09:33 AM
If your only concern is the six-bolt converter, just drill the extra holes in the flexplate. The converter is located by the pilot in the crank, not the bolts.
Old December 6th, 2012, 11:24 AM
csouth's Avatar
I was under the impression that all the holes needed to be bolted, but now I see where some Buick guys have used only 3 of the 6 bolts. It'll only be until I get my converter done anyway.
csouth is offline
Old December 7th, 2012, 04:34 AM
chadman's Avatar
Three bolts will be fine. That's all I have and I beat on it pretty hard. Just make sure to use some good ARP bolts or compareable.
chadman is offline
Old December 7th, 2012, 04:53 AM
csouth's Avatar
The flexplate to crank bolts are, I'll make sure I do the same for the converter.
csouth is offline
young olds
June 4th, 2013 07:58 AM
real57vetteguy
August 8th, 2012 07:54 AM
olds455
May 17th, 2010 04:43 PM
ctrain22
July 10th, 2009 08:13 AM
1FSTLS1
May 10th, 2008 09:40 AM
Quick Reply: Flexplate interchange for 455
