I think I bought the wrong flywheel?
I ordered the below flywheel for my auto to manual conversion from Rockauto. It says it fits '71 350 Olds, so I thought since all the research I have done says the factory flywheel is the same from '68 and up for big block and small block I should be good. I spent 10 minutes under the car and though it looks close I don't think it is going to fit. Thoughts?
http://www.rockauto.com/dbphp/mak,OL...,5348,Flywheel
1. 168 teeth is Chevy; 166 is Olds
2. Olds mounting bolts are arranged so it bolts up only one out of six potential ways.
3. I refuse to use cast iron grenade flywheels, especially Chinese cast, because my feet are discontinued.
Great, nice of them to list it as an Olds part. I know they were not putting Chevy 350s in Cutlass in '71.
Understood on the quality of the part. I have no intention of drag racing my car though. I guess I will have no choice other than upgrade to the SFI flywheel other than going used.
Thanks for the info on the tooth count.
Huh, 1968 442 engines included a 350, 400, and 455
http://www.rockauto.com/catalog/rafr...%2BFlywheel&ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=o685qh5m5adcn3qav1eme65l60
BULLSHED !!
I see there is an option to create a login and add expertise.
No flywheel listed, not under Engine or Transmission, for the 1968 400 engine 442 model.
BULLSHED !!
One more time, vendor catalogs, particularly on-line ones, are notoriously incorrect for older cars. As an example, RockAuto shows that Vista Cruisers use B-body ball joints, not the correct A-body ball joints.
oldcutlass
November 12th, 2013 02:30 PM
costpenn
22
March 24th, 2013 04:18 PM
alan69delta88
August 17th, 2006 02:13 PM
