1960 Super 88 Engine Options?
Old February 12th, 2006, 05:08 PM
bschubarg's Avatar
i have a 394 in a twodoor coupe and want to convert it to a chevy or other motor for daily cruising i don't want to put the miles on the 394 and right now rebuilding the 394 is tooo $$.
Is it possible to put a cheyv or better yet a later gen Olds such as a 455?
Any feeback will be greatly appreciated
bschubarg is offline
Old February 14th, 2006, 04:53 AM
Please don't put a chevy engine in it.....
Old April 8th, 2006, 10:40 PM
coldfire's Avatar
Well, yes its possible, an olds 455 will fit under your hood, but I would guess that the engine mounts would not line up...then again you'd have the same problem with swapping in a chev. for cheap $$ option OTHER than chevrolet you can probably find an inexpensive olds 307 or 350 since its just for cruising and not HP
coldfire is offline
Old May 30th, 2006, 06:10 PM
chopped64's Avatar
60 olds
It might to late but i just put a olds 350 in my 61 the 455 will use the same motor mounts as a 350 it will sit a littel higher. The problem is the tranny if you go with an th 350 you have to cut the tranny hump out and move it back. or get a adapter kit.
chopped64 is offline
Old June 2nd, 2006, 07:14 AM
phoenix22's Avatar
Talking
my 2 cents........the 394's bullet proof.......find the money/or lay the car up til you have the money......
if GOD had wanted a 350 chevy or other blk in it............he'd have showed up in lansing ......and installed it himself.........
phoenix22 is offline
Old June 14th, 2006, 09:26 AM
coldfire's Avatar
LOL that's hilarious
coldfire is offline
tailfins
May 11th, 2013 05:06 PM
July 5th, 2012 09:34 AM
1960OLDSSUPEREIGHTYEIGHT
August 3rd, 2009 07:14 AM
tailfins
January 23rd, 2009 11:58 PM
MRS055
June 9th, 2006 07:15 PM
Quick Reply: 1960 Super 88 Engine Options?
