1955 324ci Engine Exhaust Manifold Bolthole
Old June 12th, 2011, 09:20 AM
Shoreman's Avatar
I recently purchased a 1955 Olds 98 with the stock 324 engine. I noticed that the exhaust manifolds are attached to the heads using studs and nuts except for the bottom rearmost bolthole on the passenger side exhaust manifold which is attached with a bolt. It just so happens that anti-freeze appears to be weeping from that bolthole. Does that particular bolthole run into a water jacket in the head? Should the exhaust manifolds (originality) be connected with studs at all/any location(s)? Thanks.
Shoreman is offline
Old June 27th, 2011, 01:24 AM
oldsmobum's Avatar
I just got done a few days ago getting a bunch of exhaust leaks resolved on my 55...
On mine the four outer fasteners were studs, and the two in the middle were bolts. The lower of the two middle bolts was definitely into the water jacket, My block drained when I removed the first one.
Just for your information all of the threaded holes in the head are 3//8 x 16. The threads on the nuts however are fine thread 3/8 x 24. Basically all the nuts on the exhaust are fine thread, but the non-nutted bolts are coarse.
When I took my manifolds off 3 of the 4 studs on the left side came out, and just one did on the right. I figured I was asking for trouble trying to remove the remaining 4 without the heads off the block so I just installed bolts where the studs had previously been and put new nuts on the remaining studs.
oldsmobum is offline
Old June 27th, 2011, 06:45 AM
Shoreman's Avatar
Thanks for the information. I'll get some plastic tubs ready to catch the anti-freeze before removing the manifold.
Shoreman is offline
Oldsguy
May 12th, 2012 11:08 AM
Russ P in MD
April 14th, 2012 11:37 AM
1arunem
February 15th, 2009 04:48 PM
1arunem
February 13th, 2009 06:50 PM
55rocket
December 1st, 2004 06:23 AM
Quick Reply: 1955 324ci Engine Exhaust Manifold Bolthole
