1966 Carb advice
1966 Carb advice
Thank you for taking the time to read this. I'm a newbie here. I've looked over the forums, and I was unable to find the answer I was looking for. There was a post below that mentioned carbs for 330. I'm unsure if high compression 330 is different than just stock, also if the year car the 330 came from is different. I just purchased a 66 cutlass convertible. The car came complete, minus the carb. The guy took it off to rebuild it and can't remember what he did with it.
Here's the breakdown. From what I read the engine is a 330. I've searched OPG parts, and other retail options looking for a replacement. My frustration lies with the endless options, and
not knowing what actually goes on in the car. Understandably you can make anything fit, with adapters. I just want the least headaches, direct fit, and little to no modifications. I'm running a little blind on this as I don't have a core to go off of.
If possible direct links to the exact carb I need for this engine would be ideal. Also, not opposed to buying from someone here if it makes sense. Any advice would be greatly appreciated - remember newbie here. Thanks again.
