1966 Cutlass 330 high compression dead cylinder
I have a 330 high compression engine with a HEI ignition. All of the plugs fire, but I have a miss and it makes no difference when I remove the #8 plug wire. The plug fires out of the engine. I have swapped with known good wires and plugs. Any ideas? Thanks.
You need to see if there is compression in that cylinder and that the valves are opening and closing. If you have all of this it is then an ignition problem. You could have a flat lobe on the distributer for that cylinder. Just because a plug fires outside the engine doesnt mean it wuill fire under compression.
Sometimes it can be the simple things.
Check for a cracked spark plug or cap.
Did you try new a new wire, plug and cap?
You do need to check compression on 8 if
you think that is the bad one. Cracked ring?
I used standard AC plugs the first time and they had maybe 200 miles on them. I replaced them with AC Rapidfire plugs and that engine ran like stink!
Always, always, ALWAYS use the best spark plugs you can!
kanner1
October 8th, 2011 05:31 PM
tlucas07
March 23rd, 2009 11:40 AM
cts-v
January 10th, 2009 04:55 PM
