307/350
Old October 5th, 2002, 11:08 PM
leo lymen's Avatar
Wink
i have a 84 cutlass with a 307 cid in it. it runs good, but its just don't have enough power for me if i add a edlebrock intake and carb will lt run like a olds 350
leo lymen is offline
Old October 10th, 2002, 05:15 AM
The Charter Member
EdsDelta's Avatar
Lightbulb
It'll help, but you'll need to dig deeper if you're trying to make it comparable to a 350. I had some of my motor-heard buddies blueprint a 305 block, which had new:
Rings
New main bearing
Lifter bearings
Mail seal
Oil Pump
Distributor
Gasket set
Edelbrock Proformer Cam
Holley 600 Carb
So, I would go with the new cam at LEAST, but you should replace the above if you've got a lot of milage on your block..
Ed
EdsDelta is offline
Old October 24th, 2002, 05:26 AM
Rocket science's Avatar
Post
A cam,intake,carb and headers will help but get rid of the stock gear if you want to fell some more punch
Rocket science is offline
Old October 25th, 2002, 08:26 PM
landyacht1's Avatar
Cool
i dont know how you fell abuot engine swaps but heres an idea. im not 100 percent sure, but if it is anything like the other mid 80's gm cars i have dealt with the 307 has a standard chevy bell housing. if it does you could slip a good old fashioned 350 or 400 into that thing then you will have a great base to build your rod from. if not try to locate an engine out of a wrecked olds(pre 1973 preferably) and slap that sucker in there. just a thought, and hope this helps.
landyacht1 is offline
Old December 13th, 2002, 06:48 PM
Monster Olds's Avatar
Post
Hey there, you can get any 350 or 403 to swap over directly.
Dont be discouraged its prett yeasy to do if you have the right tools and buddys for the job.
If you are gonna swap a new intake on the 307, you may be ahead of the game to get a new cam and lifters in there since the top end is opened. Might want toss on a new timing chain while there too, it doesnt hurt any.
The Monster
Monster Olds is offline
falconsfan
May 14th, 2015 05:47 AM
carbonf00tprint
November 4th, 2012 07:53 AM
Sturgeon
October 8th, 2007 07:29 AM
Pinner
March 11th, 2007 07:11 PM
Quick Reply: 307/350
