330 CID Timing Mark
Old August 24th, 2009, 12:28 PM
bluecutlass's Avatar
330 CID Timing Mark
Can anyone tell me about the timing mark tab on a 65 OLDS 330 Engine?
I am confused where 7.5 degrees BTC is.
Facing the engine, standing at bumper there are 3 slots on the tab
Slot on left has a square hole under a round hole
Slot in the middle nothing
Slot on right has one round hole
Where would 7.5 degrees BTC be?
bluecutlass is offline
Old August 24th, 2009, 12:34 PM
The round hole is a zero, as in 0 deg or top dead center. The "square hole under a round hole" is actually a one and a zero, as in 10 deg BTDC. The center slot is between 0 and 10, so it's 5 deg BTDC. 7.5 would be halfway between the 5 deg and 10 deg marks.
joe_padavano is offline
Old August 25th, 2009, 04:01 AM
Thanks Joe
It was to simple to spot. Engine runs alot better now with correct timing.
getitmann
July 12th, 2012 06:58 PM
MDchanic
July 18th, 2011 08:49 PM
Homestar
March 22nd, 2011 03:25 AM
al714
November 16th, 2009 07:41 AM
lunatic
January 14th, 2005 12:02 PM
Quick Reply: 330 CID Timing Mark
