330 olds engine oil still black after fresh oil change
Old June 2nd, 2023, 10:55 AM
Cutlass67Cutlass's Avatar
Can anyone give me a reason why my oil stays black even after I change the oil?
Cutlass67Cutlass is offline
Old June 2nd, 2023, 11:08 AM
How long do you run the engine between oil changes? Does the engine run well? A gas engine shouldn't have sooty black engine oil like a diesel engine.
Olds64 is offline
Old June 2nd, 2023, 02:30 PM
Because the inside of your engine probably has some sludge build up and the detergents of your oil continuously breaks this down. Your engine also may have some blowby that will also contribute to contamination.
oldcutlass is offline
Old June 2nd, 2023, 02:57 PM
Rocket Renegade!
How frequently are you changing it? Are you doing the filter as well?
BangScreech4-4-2 is offline
brianbeez67
May 22nd, 2022 06:50 AM
72455
April 3rd, 2022 07:08 AM
Gary M
April 5th, 2017 08:05 AM
olds67
December 5th, 2009 01:11 PM
Quick Reply: 330 olds engine oil still black after fresh oil change
