350 Rocket
Old January 29th, 2014, 10:05 PM
88cutbrougham's Avatar
350 Rocket
I'm New to the forum but i figured this would be the best way to get real direction on my 350 rocket. i have a 88 cutlass with 307 in it but i want to replace with 350 rocket. i just bought a 350 rocket bare block and wanted advice about which crank, heads, camshaft etc to get to make it perform. im not familiar with oldsmobile. So im kinda in need of info so i can put project together.
88cutbrougham is offline
Old January 30th, 2014, 12:45 AM
DoubleV's Avatar
You need to state your goals and budget before anyone can give you any advice.
DoubleV is offline
Old January 30th, 2014, 03:03 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Where is your location? i have most of the stuff you'll need laying around randomly.
J-(Chicago) is offline
Old January 30th, 2014, 03:04 AM
this is the most important. . you're looking at 4-6000 bucks to build a brand new one from scratch , likeyou plan to.
Old January 30th, 2014, 05:22 AM
Old School Olds
tru-blue 442's Avatar
Hmmm...I might have a 67 330
crank for it. Need to ask my son.
4-6K for a rebuild, anyway.
I'm going with 5 or above.
What are your plans for the top end?
tru-blue 442 is offline
Old January 31st, 2014, 09:21 PM
Im in MI, and i wanna spend between 1500-2000. not sure about what I want to do with the top end....this is my first rebuild project.
Old February 1st, 2014, 07:04 AM
I'd advise finding a good running used engine or holding out until you have a better budget to work with.
Old February 1st, 2014, 07:08 AM
Chevy budget Olds powered
coppercutlass's Avatar
A member here had a nice 355 for sale for a fair price with good parts just the short block.
coppercutlass is offline
Old February 1st, 2014, 07:48 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
You can use your 307 crank and rods, just needs rebalanced. He should be able to get the block together for 2 grand, heads no way. Get either the CP or Probe pistons for it, depending on the shape of the block. What compression are you aiming for?
olds 307 and 403 is offline
Old February 1st, 2014, 07:50 AM
captjim's Avatar
Like J stated, that isn't going to get you very far, especially with other upgrades you will need like exhaust and cooling. Find a running 403, pop on some older 350 heads for a compression bump and a little cam.
captjim is offline
69OLDSCUTCONV
February 1st, 2011 06:09 AM
cutlassKing
November 29th, 2010 03:05 PM
gscott819
July 28th, 2009 07:02 PM
esisson
May 22nd, 2008 07:47 PM
<Eddie>
November 1st, 2005 07:30 PM
Quick Reply: 350 Rocket
