403 Cyl head frost plug
I have a 403 installed finally into a 1977 Silverado, which has a leaking frost plug on the passenger side cyl head, how tough are these to change, Ive never done one before, any ideas?
Al
Al
Being on the head, it should not be that bad. I am assuming you have plenty of room to work since it is in a truck. What I would do is take a brass punch or something else that won, punch through the freeze plug and try to hit it so it flips the plug sideways so you can grab it with some pliers and pull it out. Try not to knock it all the way in the head. Use a brass plug to replace it.
ds00469
January 25th, 2014 05:12 PM
OldsManNJ
November 17th, 2010 11:47 AM
