#5 main cap sealant?
Old March 10th, 2015, 08:25 AM
SkylinesSuck's Avatar
I am replacing the rear main seal with a 2 piece neoprene job and looking at the FSM. It calls for some type of sealant on thr main caps themselves. What is this and do I need it?
Also other kinda related question; plastigauge measures between .003 and .004. Leave it alone and button it back?
SkylinesSuck is offline
Old March 10th, 2015, 08:43 AM
morgan
pogo69's Avatar
you should use a dab of rtv at the joining areas of the rear seals to help prevent a leak and also offset the seals in the block about a 1/4 inch
pogo69 is offline
Old March 10th, 2015, 08:47 AM
morgan
pogo69's Avatar
.003 - .004 on rear bearing 5 is ok....on the others thats a little loose but not terrible there is more of a risk of failure at that higher number on 1-4
pogo69 is offline
Old March 10th, 2015, 09:27 AM
Octania's Avatar
I recommend some sealer OTHER than RTV which can and does ooze out and make strings that break off and go elsewhere.
Form-a-Gasket #2 non-hardening
Permatex 3H aviation sealer
Yamabond at your Yamaha dealer
are some good choices.
Octania is offline
Old March 10th, 2015, 09:45 AM
morgan
pogo69's Avatar
i will agree there are other sealants you can use as above... rtv is sometimes tricky to use you want a thin consistent one piece bead....not blobs of it that can shred
pogo69 is offline
Old March 10th, 2015, 09:46 AM
Great info, thanks. And just to be clear, I am not talking about a dab of RTV on the ends of the neoprene seal. I know I need that. It seemed like the fsm wanted some sort of sealant on at least a portion of the mating surface of the cap/block itself.
Old March 10th, 2015, 09:53 AM
morgan
pogo69's Avatar
yes i was also referring to that also ....running a bead down each side of the ridge in the block side to completely seal the cap
pogo69 is offline
Old March 10th, 2015, 11:51 AM
You're talking about the sealing surface between the #5 main bearing cap and the oil pan, right?
Because, just to be clear, there is no sealant used between the bearing caps and the block, or between the oil pump and the bearing cap.
MDchanic is offline
Old March 10th, 2015, 04:48 PM
Old March 10th, 2015, 05:05 PM
morgan
pogo69's Avatar
that sealer is similar to the aviation permatex ....that is the ridge i was referring to ( on the block) i just happen to use a bead of rtv along both sides as in the pic
pogo69 is offline
Old March 10th, 2015, 05:52 PM
You mention a ridge; I see a little valley on the cap that is also pictured in the FSM. Is that what you mean? It ison either sideof what I'm guessing is where the thrust collar rides. It looked like there was some type of sealant in there when I pulled the cap and I have since cleanedit out with a razor.
Old March 10th, 2015, 07:13 PM
morgan
pogo69's Avatar
Ok ridge is confusing i bead the area on far rear lenghth of the block
where the cap butts to the block the bead starts at the seal end and back a little then across
pogo69 is offline
Al2011
November 20th, 2013 07:15 AM
at3reg98
November 15th, 2013 07:51 PM
smietana
October 31st, 2013 12:21 AM
Al2011
March 11th, 2013 08:04 PM
krooser
January 17th, 2013 10:15 PM
Quick Reply: #5 main cap sealant?
