64 330, smoking very badly
Hello,
My 64 330 maybe done. It will only run with the carb being super rich. I have lots of blow by and lots smoke. I was wonder where is a good place to sort new parts such as piston rings and intake/exhaust valves. I think I need to do a complete rebuild and I want to see if its worth it compared to getting another motor.
Thank you
Thank you
Me, I would hang on to the original
engine if that is the one. Find a nice
350 runner for the time being. You may
have to use your flex plate on the 350.
I think one of our Texas members, project bedlum,
has a combo for sale for very little $, out of his 72.
The man's name is Ralph. Good luck with it.
If you want to economize, there are a lot of good used 330's out there and for reasonable prices.
A lot of good 330's and 350's are being replaced with 455's.
I was about too convert my driver, a '67 Cutlass, to a 4-4-2 clone using a '67 4-4-2 drivetrain.
For some reason I came to my senses and realized that 330 was a perfectly good engine with plenty of power and easier on gas.
A good used small block might be a good, economical option to consider.
Just make sure you can hear it run before you buy.
('64 Jetstar-neat car!!)
If you picked up Ralph's unit
you could use the trans and pick
up an extra forward gear as well, J/S.
Drive shaft would be a question
along with shipping costs though.
a few years back i did a compression test and i had one cylinder at 75 psi and the rest around 125 psi. it started life as a 2bbl "ultra high compression" motor, which I take to me a 10.25:1 motor. and by smoking badly and running badly i couldnt keep it running long enough to go around the block. it died on me about 4 times. I am not condemning the motor as much as trying to figure out where to get what I need, I would love some big crate olds motor, but my budget appears to be more towards the rebuild the the 330 or pick up a wrecked LS car and do the evil swap. It used to run pretty good with the edlebrock manifold and demon carb. The only reason I have havent torn down the heads yet is that one of my exhaust manifold is cracked right through the bolt hole. I have not be able to get an exhaust manifold or a clear answer on what aftermarket manifold/header i can use.
There is a member looking for a certin block date might want to check it and see if it's what he needs could be some funds to do the swap with the funds needed to rebuild just a thought
Also I have a set of big block but really they are small block manifolds not sure if the will work with your car but your welcome to them just pay shipping.
Also what's your location I will be pulling a 330 in the next year that runs great but it is 50 years old
You guys are always killing me for suggesting everything be done high-dollar, how does this sound for a "budget build"?
Find a relatively low mileage, running 403. Pop on some 350 heads, or if you want to go stealth mode, rebuild your 330 heads. On quick glance, only pros like Joe P will know the difference. CR should be a street-friendly 9 to 1 +/-. Swap in a cam in the 210/.480 range, new chain and gears, you already have the intake and carb. It is a direct bolt-in, and you will have a torquey 400+ CI small block for less than a grand.
I do agree that it might be a bit premature to condemn the 330, without more investigation.
buy budget i mean 10k for a create motor is high, 2k for a rebuild is reasonible,
does this like like a good way to use up 2k?
Qty Update Remove Part Number Edit Oversize Description Item Price Line Price
Update QTY
44058K ROCKER PART $11.69 $93.52
Update QTY
48054 PUSHROD $4.25 $68.00
Update QTY
78113 .250 DOUBLE ROLLER SET $73.75 $73.75
Update QTY
CB684.000 Edit Oversize ROD BEARING $7.01 $56.08
Update QTY
L2227-8.000 Edit Oversize PISTON SET $360.26 $360.26
Update QTY
MS2805.000 Edit Oversize MAIN BEARINGS OLDS 330/350 $82.76 $82.76
Update QTY
O-6 CAM BEARING SET $34.69 $34.69
Update QTY
S2494 EXHAUST VALVE $9.39 $75.12
Update QTY
SRH636.000 Edit Oversize RING SET $49.56 $49.56
Update QTY
TC498 TIMING CHAIN $20.40 $20.40
Update QTY
TS348 CAM SPROCKET 330/350 OLDS $10.71 $10.71
Update QTY
TS349 CRANK SPROCKET $6.74 $6.74
Update QTY
V2495 INTAKE VALVE $6.12 $48.96
Update QTY
VL51 VALVE LIFTER $3.40 $54.40
Update QTY
VS891 VALVE SPRINGS $3.83 $61.28
Update QTY
P-225ANEWHV 1964-UP OLDS 330, 350, 394, 400, 425 & 455 NEW H.V. OIL PUMP $116.50 $116.50
Update QTY
60-1424-45 NEW PERFORMANCE CAMSHAFT $413.26 $413.26
Total: $1625.99
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Update QTY
Total: $1625.99
You can't do a rebuild with new pistons for 2 grand, it will end up being double that, even if you assemble it yourself. Like oldstata stated, machine work will run $1500 minimum, and you left out gaskets and other misc stuff like fluids that add up. Not saying not to do it, but it won't be for $2000.
I just copied and pasted the first thing i saw on egge. That whole thing was $1600. I am not afraid to spend money on it. A rebuild i can do slowly over a few months, if i get another motor i dont want to have to do anything to it but drop it in and go. I need to get my pos wbodies out of the way and free up some room in my garage but i am in the middle or replacing both transmissions in them.
This was stainless steel, now i have to find the steel again lol. It was nice and shiny until it started smoking. The other thing it did is stall out while driving, it would just cut out.
Find a good running mid 70's Olds 350 or a late 70's 403. I have found good ones for $120 to $400. The late 76 350, I paid $120 for, had 140-142 psi all 8 cylinders, hot oil pressure of 20 at idle in gear and 45-50 at cruise. I added a Performer cam, Cloyes timing set I already had and a $12 Fel Pro gasket set and an AMC rubber rear main. Deals are out there.
The block and the heads. Bore, hone, align hone, deck, hot tank, cam bearings installed on the block, then the heads done. Not trying to be rude, but if you are asking that question, you aren't ready to do this. Take some time to read a book or do some research online.
Machine work depends on the condition of the block I would ask there prices and prepare for the worst.
If your going to rebuild I would recommend buying a 350 use the crank from the 330 and build it right or go 455 depends what your after
Also does any one know if the #1 and 4 manifolds will work on the 64 88 for him.
They were on a 72 88or98 big car thanks for any help
I had my block vatted, decked, bored, cam bearings installed, new Egge pistons, rods resized, crank turned, everything balanced, heads milled, valve job, gasget set, freeze plugs, Cloyes timing set all for $2400. Thats here in Texas, in Houston. I assembled the engine. Bought cam and components from Cutlassefi.
9drsixwheelolds
November 1st, 2010 09:15 AM
