68 442 carb #
Old April 1st, 2014, 05:18 PM
krazee442man's Avatar
68 442 carb #
OK, I need some advice guys ! So the #'s on a 68 4spd carb should be 7028251, right ? So what is a 7028251 RJ ?
krazee442man is offline
Old April 1st, 2014, 05:53 PM
Trying to remember member
wmachine's Avatar
Same carb. RJ is the broadcast code for that carb. Most OE carbs of that era had the broadcast code on it.
wmachine is offline
Old April 1st, 2014, 06:19 PM
Thank-you . So if I can find one for $ 90 that would be a good price ?
Old April 1st, 2014, 06:32 PM
allyolds68's Avatar
A core just sold on e-bay for a little over $115 so $90 is in line.
http://www.ebay.com/itm/Rochester-Qu...b97f1a&vxp=mtr
I assume you're talking about this one: What's the build date of your car? This is a mid Feb build date
http://www.ebay.com/itm/1968-Oldsmob...f2fef9&vxp=mtr
allyolds68 is offline
Old April 1st, 2014, 07:09 PM
Yes Mike, that is the one I was looking at. My car has a build date of 01C. Are these carb #'s for ALL 442's or just W-30's ? I am curious , when the carb and distributor #'s are mentioned for the W-30's does that mean only them or where these used on all 442's of that year?
Old April 2nd, 2014, 06:46 AM
442Harv's Avatar
The number for a W30,is 7028254
442Harv is offline
Old April 2nd, 2014, 07:42 AM
allyolds68's Avatar
The 7028251 was used for all big blocks (400's and 455's) in 68 with the exception of the Toro's and W30's. There is some evidence to suggest that the 7028253 was used very late in the production year for some manual trans 442's. (I think H/O's used 708255's and 7028251's but I got that from 442.com so I'm not sure)
Old April 2nd, 2014, 09:18 AM
wmachine's Avatar
With the 7028255 being the W31 carb, I think it is safe to say it was not used on the H/O.
wmachine is offline
Old April 2nd, 2014, 11:27 AM
allyolds68's Avatar
Like I said Kurt, I got it from 442.com . Consider the source
Old April 2nd, 2014, 01:57 PM
442Harv's Avatar
The Hurst, used# 7028251.
442Harv is offline
Old April 2nd, 2014, 05:28 PM
Thank-you, this all helps. So the 68 4spd W-30 used 7028254, now what about 68 AUTO W-30 , what is the carb # for it ? Again, thank-you all for your knowledge. I am putting all in my notes so I can properly restore my two 442's.
Jim
Old April 3rd, 2014, 06:45 AM
442Harv's Avatar
Auto used the same carb.
442Harv is offline
Old July 30th, 2014, 04:47 PM
Octania's Avatar
In production, sure
I missed buying a parts car a long time ago due to lack of fundage
It had D heads, and an '8255 carb
Local gearheads probably used whatever W-machine parts worked best.
I have a TSB that shows the engine unit number at which they switched the W30 usage from '8251 to '8254. Used to be on RealOldsPower.com; might be here somewhere- try a search on "7018151" & "7028254" & "date" or "TSB"
Octania is offline
Old July 30th, 2014, 05:30 PM
72xw30's Avatar
The 7028255 (W31) carb was used on all 68 non a/c Hurst Olds (W45).
The a/c cars (W46) received the 8251 carb.
Cheers,
Sam
72xw30 is offline
Old July 30th, 2014, 06:32 PM
dnmfranco's Avatar
Cheers,
Sam
yes sir non a/c 255's
dnmfranco is offline
Old July 31st, 2014, 12:48 PM
StickW31's Avatar
X100 absolutly Dean & Sam . Also the 8255 car is a very rare carb, I think even more than the 7040255 carb, hmmmmmmmm ? LOL
Steve
StickW31 is offline
joepenoso
July 19th, 2013 12:44 PM
Don R
October 6th, 2012 09:47 AM
RandyS
October 4th, 2012 12:36 PM
BigBertha442
March 13th, 2008 03:48 PM
Quick Reply: 68 442 carb #
