69 Cutlass Carb
Old June 7th, 2012, 11:23 AM
spate51's Avatar
69 Cutlass Carb
Trying to decide which carb to put on my 69 350 MT Cutlass project. Have 3 quadrajets; 1985 Chevy (will use for some parts maybe), 1969 for a 400 MT, and a 69 buick 350 MT version. Leaning toward the 7029251 (400CI) since I have the rebuild kit.
The chevy qjet is on the running car now. It came with it.
Suggestions and or comments appreciated. Start the carb work this weekend.
Speve P
El Paso
spate51 is offline
Old June 7th, 2012, 11:47 AM
delete
droptopron's Avatar
An '85 Chevey should have electronic controls, no? I'd choose between the two older carbs based on what is in better condition.
droptopron is offline
Old June 8th, 2012, 06:31 PM
Octania's Avatar
The 7029251 is a close match for your application; slight jetting differences mainly.
Rebuild, adjust EVERYthing, it should be fine. Start with ensuring the throttle plates open to exactly 90 degrees at a full pull on the cable-
http://www.realoldspower.com/phpBB2/...ic.php?t=83237
Octania is offline
Old June 8th, 2012, 06:45 PM
Just the facts...
BILL DEMMER's Avatar
the 7029251 would be the best choice, depending on it's condition, it will require some recalibration. it should have the correct throttle end and choke assembly. the 350 would use AT secondary rods, the 455 will have AU's.
bill
BILL DEMMER is offline
joepenoso
July 19th, 2013 12:44 PM
Don R
October 6th, 2012 09:47 AM
RandyS
October 4th, 2012 12:36 PM
macarthur
January 10th, 2007 05:19 AM
87CUTTY
November 15th, 2006 01:15 PM
Quick Reply: 69 Cutlass Carb
