71 cutlass 350 stock th350 tranny stock
Old November 23rd, 2012, 09:17 PM
delta254's Avatar
Hey guys just wondering if anybody knows why when Im on the hiway say going 65 or 70 and I let off the gas my cutlass seems to make a popping or kind of backfire noises....I know its not back fire the RPM's are over 3000, When I put my headers on and had open headers going to mufller shop I could hear it worse then i got pipes welded to collectors and know still hear it but not as bad as with open headers.Any suggestions thanks
delta254 is offline
Old November 23rd, 2012, 09:23 PM
Chevy budget Olds powered
coppercutlass's Avatar
It's exhaust gasses re iginting as they are exposed to oxygen nothing bad. This is what i was told atleast years ago.
coppercutlass is offline
Old November 29th, 2012, 06:40 AM
jpc647's Avatar
I have a similar "problem" Many told me it might be a rich condition with the carb. I leaned it out, the noise went away, but it seemed to no have as much pick me up after say 35mph.
jpc647 is offline
Old November 29th, 2012, 03:32 PM
delta254's Avatar
What do you mean by "leaned out" settings?
delta254 is offline
Old November 29th, 2012, 07:23 PM
jpc647's Avatar
Sorry, on my edelbrock 1406 carb, there are two idle mixture screws. I turned them both in about 1/2 a turn. The popping stopped almost completely. At 80mph at WOT if I let off completely, it would pop a couple of times and stop. I assume thats normal.
But again, leaning the car out like that did negate performance around 30-35mph. Second gear didn't seem to have the same pull, so I turned them back out.
I may have a slew of other problems, but this happened to me. Maybe someone else can explain as to why.
jpc647 is offline
Old November 30th, 2012, 08:11 AM
Leaning the idle air/fuel mixture will have no effect on your performance off idle. So you have another problem.
As copper said, it's normal, unles it's a very loud backfire. Hi flow exhaust are a bit noisier than stock.
oldcutlass is online now
Old December 3rd, 2012, 08:37 AM
jpc647's Avatar
When you let off the gas completely while doing 65 it would have an affect. Mine would only pop if I cruising and completely let off.
But granted the other problem is not related and relates to another cause.
jpc647 is offline
L69
January 5th, 2012 01:29 PM
hunter
December 3rd, 2011 06:57 AM
gscott819
July 28th, 2009 07:02 PM
Pghstarsky
September 13th, 2007 11:09 AM
Quick Reply: 71 cutlass 350 stock th350 tranny stock
