84 - 307 locating water and oil pressure lines o
Old October 17th, 2004, 04:19 PM
<mr.stew@netzero.net>
Guest
Posts: n/a
Post
there are three sensors on front of block . Which one is the temp gauge. And where is the oil pressure sending unit? I want to install gauges,rather than idiot lights. Any help will be appreciated. Thank"s Mike
Old October 18th, 2004, 11:20 AM
Past Administrator
Oldsguy's Avatar
Post
On most Oldsmobile V8s. The water temperature sending device is on the right front of the intake manifold on the water jacket runner (front one that runs all the way across). The sending unit is vertically screwed into the manifold. All you have to do is remove the sending unit and replace it with the sending unit for an aftermarket gauge, or, if you want he idiot light to still work, install a "T" first and mount both units on the "T". There MIGHT be another spot on the left side of the same runner that is not used and you could put your sending unit there. For the oil pressure sending unit, look on the front of the block, on the horizontal shelf just below and to the right of the thermostat housing, it is between the vertical block surface and the front timing cover. It is actually part of the block.
Good luck.
Oldsguy is offline
dacutty
March 28th, 2014 09:01 AM
foreverolds
December 1st, 2012 07:07 PM
flatoz
August 9th, 2009 06:49 PM
flatoz
Drivetrain/Differentials
August 9th, 2009 06:48 PM
texasred
July 31st, 2007 10:18 AM
Quick Reply: 84 - 307 locating water and oil pressure lines o
