Aluminum heads
Old December 29th, 2013, 02:53 AM
Oldskool84's Avatar
Aluminum heads
Edelbrock rpm performer vs AFR , significant difference or just personal preference ?
Oldskool84 is offline
Old December 29th, 2013, 04:47 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
AFR doesn't make Oldsmobile heads that I know of. Procomp are similar and a good deal from Benard Mondello. The heads with a 350 need the chambers milled to 70cc to take full advantage.
olds 307 and 403 is offline
Old December 29th, 2013, 08:30 AM
oddball's Avatar
The current Edelbrock heads have a new chamber that may or may not be better. Procomp is a copy of the original Edelbrock but the components are pretty cheap and they can use some final machining/clean up. Don't trust the valve guides. Hence get it from a trusted Olds vendor like Bernard Mondello (*not* "Mondello" in california).
oddball is offline
Old December 29th, 2013, 12:27 PM
Oldskool84's Avatar
Sounds good ,thx!
tocicar8825
September 21st, 2021 07:10 AM
import extermination
July 12th, 2015 08:30 PM
shermanator
February 27th, 2010 01:36 PM
ratsglass29
November 6th, 2007 02:24 PM
Quick Reply: Aluminum heads
