Bang for your Buck
Old September 13th, 2013, 11:10 AM
my71olds's Avatar
Bang for your Buck
So we rebuilt the original heads on a 350 olds in a 71 Cutlass. As for engine performance what is the next best bang for your buck?
rebuild the carb
ignition improvements
my71olds is offline
Old September 13th, 2013, 11:32 AM
Timing Optimization
Compression (pistons)
Cam
Headers & Dual Exhaust
You won't get anything out of ignition changes for a stock-ish motor, unless you need a tune-up anyway.
MDchanic is offline
Old September 13th, 2013, 12:12 PM
my71olds's Avatar
Originally Posted by MDchanic
Timing Optimization
Cam
What is needed for Timing Optimization?
my71olds is offline
Old September 13th, 2013, 12:16 PM
The '71 was set unusually retarded for emissions reasons.
Once you have the rest of your setup the way you want it (or before, if you want to do it twice), you need to use a timing kit (Crane's is good) to modify the advance springs and advance canister to get the timing where it works the best, and determine the best vacuum advance source, manifold or ported.
MDchanic is offline
Old September 13th, 2013, 12:48 PM
delete
droptopron's Avatar
Gears - I went from a 2.73 (maybe even a 2.56?) to a 3.23 that is still modest but its a night & day difference. The revs were upped on the highway but nothing that is not tolerable.
droptopron is offline
Old September 14th, 2013, 10:06 PM
64Rocket's Avatar
Should have milled some off the heads, to help compression.
replace timing chain
As what was said "Gears"
Gene
64Rocket is offline
Old September 15th, 2013, 02:56 AM
Kennybill's Avatar
If the heads are still off you might want to consider a small camshaft upgrade. Just don't over cam it. A small rv (torque) cam along with tuning/exhaust/gears. Jmo, Ken
Kennybill is offline
71murder
Suspension & Handling
23
August 27th, 2021 01:31 PM
jag1886
October 14th, 2013 08:25 PM
rocketrickshaw
July 19th, 2009 07:31 PM
Jokers69
March 28th, 2008 10:47 AM
GoldOlds
June 14th, 2007 10:14 PM
Quick Reply: Bang for your Buck
